Old 09-16-2012, 07:14 PM
theamcguy's Avatar
theamcguy theamcguy is offline
You have water that is 230 degrees in the block and water that is 130 in the radiator, you have a flow problem. Either there is a physical obstruction in the block preventing the water from leaving or the pump is inadequate to move the water out of the radiator into the block.
Bill Strobel
Owner Independent Towing
1965 GTO Nightwatch Blue/Aqua
2005 GTO Quick Silver/Red
Fayetteville, NC
Do It Right or Don't Do It All
Old 09-16-2012, 07:28 PM
Garage Goat Garage Goat is offline
Those are my exact thoughts. I would pull the thermostat and check the flow with a garden hose. ( with the car off)
Old 09-16-2012, 08:03 PM
jray1 jray1 is offline
That's what I have been kind of thinking but I see it circulating thru the radiator. Just may not be enough. I don't know what to do if it is slow flow as I stated before its a fresh build and the block was tanked and cleaned at the machine shop. I will try to check the flow more closely and try to figure out if it is enough.
