Old 10-16-2012, 09:18 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by 65nss4spdGTO View Post
Congratulations Jack on hitting the 7 second mark. 7 second Pontiacs are few and far between in comparison to the "other" brands. I'm curious as to the number of hits you made on the car this year to reach your goal?
Calvin Hill
Hill Performance
708-250-7420
I started looking over some of my logs and about 5 passes were last years, so about 32 passes this year. One motor pass, then I had two or three nitrous passes when I had electrical problems. Rewired the car. Went out and started spraying one system. Then started working on two, then turned the plate on before the fogger and that seemed to make a big d.ifference in how the car left. It was NOT that way at Norwalk. The things we learned after Norwalk I am confident we could have gone a high 8.0 or low teen back then.
Ran 4 passes at Yellow Bullet Nationals in 8.50 index, so I dont really consider that tryn to get in the 7s.
So honestly a little over 20 passes to learn what the motor likes and the chassis likes to tune it in the 7s.
I never nipped a plug all year, never changed the head gaskets. I ran a compression test three times and they were all around 175 lbs, except before this last time out 4 and 6 were 150 and 155 lbs respectively.
I don't consider myself some great nitrous tuner, but I can read a plug and adjust and try different things from there. But I am sure that what Gaby did to the chambers and the motor made the tuning window much larger. Which just makes me look good
Thanks also to my pit biotch Woody, a friend since high school and to Brian, Jeff and Mike for all the help at the track. ECMTTFMF!
[email protected]. 3460#s
Old 10-16-2012, 09:48 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
good job jack and Gaby..
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 10-16-2012, 10:39 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
We are in the process of adding the "Special Deck" insert into the E-heads like we have done with the Tigers. To date, this has proven to increase head gasket life, I was curious if you felt this would help?
Thanks.
Calvin Hill
Hill Performance
708-250-7420
