Most rear disc kits have a requirement for a particular flange and center register diameter. Will depend on the kit. Read the install instructions prior to purchase. For example, the Right Stuff Kit I just used on a non-C-clip BOP 10 bolt uses a axle flange diameter of 6 3/8 and a rotor center of 2.915 for the hole.
My axle flange pattern for the A body is a 3.375 center to center top bolts, and I don't see it listed on the Wilwood site. Yours should be a 3.125 on your 'bird, and I don't see that one listed on Wilwood either. I think their' chart may be off, might want to call them. Pretty sure they have rear kits for 10 bolts. .
HWYSTR455,
That's correct, my rear axle housing flange measures 3.125" and it's not shown on Wilwood website. I had already spoken to them twice (hope their products are better than their customer service/tech reps) and after each call I didn't feel confident with the accuracy of the information they provided. I trust and rely on the memebers here to help guide me. Anyone install a Wilwood rear brake system on a late 2nd gen coporate 10 bolt? thx. |
You called Wilwood and they couldn't tell you if they had a caliper bracket for a 3.125 10-bolt?
Call and ask for post-sales tech, tell them you have the kit for the 3.500 axle, and ask why it doesn't fit. They may be able to give you a better answer! .
