Old 11-07-2012, 12:30 AM
67SS&99SS 67SS&99SS is offline
Peter,
I ground that lug on the calipers because when I first installed them they were hitting the brackets. Your right, there was no way the bolts were going to line up in the brackets without doing so. I also had to grind the casting around where the brake hose end fits onto the caliper. The casting was setup for a hose that had rounded ends on it whereas my hoses had squared ends, so I had to relieve this area slightly. I checked to make sure that I had adequate clearance and that I didn't have any interference between the caliper and bracket after grinding and I was good to go. The bolts went in easily when I all I had was the empty caliper sliding over the rotor and bolting it up that way. I really had to work with the bolts to get them started after putting the pads in the calipers. I noticed the brake pads were thicker than most I've seen for some reason.(I've seen a bunch of them, used to work in engineering for a facility that made them a few years ago) I wonder if this could be the cause of it?
Andy
1962 Tempest Lemans 4 cyl auto
1967 Camaro
1969 C/10
1969 D300
1972 K/5
1974 'Cuda
2005 2500HD Duramax
Old 12-14-2013, 02:37 PM
bbscamp bbscamp is offline
this like says Celebrity Rotor, fairmont MC, firebird calipers: https://scarebird.com/index.php?rout...&product_id=76
S10 calipers are mentioned on this thread. that's why I asked. an ebay ad that you have specifies 85-90 Park Ave rotors.
Is the links / parts correct? I'm going to buy the plates for sure. But I want to get all the right parts before I start! I'd also need to hose part number and adapter. Is that in the reg. directions that come with the kit?
thanks (sorry about hijacking the thread)
Old 01-12-2022, 05:30 PM
So i am bringing this thread back from the dead. I am working on this car again for the first time in years. I had the engine rebuilt, installed a holley sniper EFI and the car is running great.
I'm going through the brakes again since this thing has sat for almost 10 years. I have no idea where the install instructions parts list went for my scarebird kit and after bleeding the brakes several times I'm not having any luck with getting a pedal so I wanted to replace the master cylinder and calipers and rebuild the wheel cylinders so that everything is up to par.
Do any of you have a make/model parts list for the master and calipers? I understand that scarebird has revised the brackets since mine were made and use different parts. The brackets I have work with the original drum hubs.
Thanks.
Name:	tempest 4 cylinder.jpg
Andy
1967 Camaro
1969 C/10
1969 D300
1972 K/5
1974 'Cuda
2005 2500HD Duramax
