Old 11-17-2012, 11:28 PM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
Default Leaky input shaft seal on steering box...
I gotta replace the seal on the input side of my steering box , on the wagon...
is it fairly easy to get the seal out? and where is a good source for seals? At first, i thought it was the lower seal, but its obvious that its the upper input shaft seal, thats leaking.Im gonna remove the box and do both seals...
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,([email protected])1.578 60' Oct 2010!!
Old 11-18-2012, 11:21 PM
GStage1's Avatar
GStage1 GStage1 is offline
Easy job, takes all of 10 mins...you can get the $10 kit from NAPA....see my article:
http://www.buickperformanceclub.com/...BoxRebuild.htm
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 11-19-2012, 09:10 AM
2002Z4CSS's Avatar
Thanks for the link. I need to reseal the power steering box on my GT-37. Looks pretty easy.
1971 Pontiac GT-37
Old 11-19-2012, 06:11 PM
Lemans1970 Lemans1970 is offline
Can the input seal be replaced with the steering box in place, just disconnecting the rag couple?
Old 11-20-2012, 12:06 AM
GStage1's Avatar
Yes, it can be done in the car but more work/effort.
George Nenadovich
Old 11-20-2012, 09:47 AM
falcon4's Avatar
falcon4 falcon4 is offline
I did this only last week.....well I actually started 3 weeks ago, while the box was still in the vehicle.....what a PITA. I couldn't get the circlip out as it was on the low side and I had no clearence for the circlip pliers.
Best thing to do is unbolt it from the vehicle and do it in a vice. Then it should only take a few minutes. I pulled the circlip, picked out the dust cover and with a screw driver prised out the seal. Easy.
'66 Valiant Regal 225
'72 Lemans Station Wagon T-41, 455
'76 Trans Am 455
'77 Ford F-100 4WD 351
'78 Ford F-100 2WD 302
'79 Firebird Black 301
'79 Z28 350
'79 Trans Am 403 numbers matching
'04 Ford Falcon XR8 5.4 ltr.
and no wife.........Yipppeeeeeee
Old 11-20-2012, 09:56 AM
Couple of follow up questions:
1. When you say more work, do you mean just more awkward to get at the snap ring and dust seal. From your description it sounds like the inner seal in fitted into the jam nut, so I wouldn't think that too be problematic?
2. In your article you stated to "Use a lil oil on seal ID to prevent a dry seal contact with input shaft". Just to clarify, you mean motor oil and not power steering fluid as the lubricant, or does it matter?
TIA
Good article BTW.
Old 11-20-2012, 03:25 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
TIA
Good article BTW.
Generally one should lubricate the sealing surface(s) of a replacement seal with the same oil that it will be sealing - so P/S fluid would be the best choice in this case.
That said, plain ol' Vaseline works well on P/S pump and gearbox reseals, as well as on automatic transmission seals.
Regards,
"455HO" Lloyd
Old 11-20-2012, 04:14 PM
Thanks for the earlier responses.
One further question. In the posted article, it states to mark the position of the jam nut prior to loosening so that it may be restored to the same position. I would presume that if for some reason the nut is not sufficiently tight the seal will leak. Does over tightening lead to premature wear of the seal (only), or does over tightening lead to any other difficulty?
Thanks again for the responses.
Old 11-20-2012, 11:11 PM
GStage1's Avatar
Yes, you can overtighten that nut, that is why I stated to tighten to the same position...sort of like the wheel bearing nut.
Use vaseoline or ps fluid to lube the seals and you will be fine.
George Nenadovich
Old 11-21-2012, 11:51 PM
thanks for the info! Im gonna pull the box this weekend and stop that pesky leak!
Old 11-22-2012, 11:42 AM
FWIW, one thing I read about this subject on another board is that it is a good idea to wrap the spines on the input shaft (with tape or heat shrink wrap) prior to re-installing the jam nut in order to prevent nicking/damaging the new seal.
