#641
I used the purple stuff degreaser and water and let it soak in a tub for about 8 hours. Then a lot of scrubbing with a nylon bristle brush. The problem is that the bell housing is so big you have to cut the degreaser with water otherwise it would take 10 gallons of the stuff to do the proper 100% degreaser on a part that big.
#642
You can actually make one up in "welding class",quite easily....
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
#643
I may actually have an old dented pan with the baffle. I will go check. Thanks for giving me the heads up. Sometimes you're so busy doing something, you just don't notice the obvious things that are missing!
#644
I just checked out the garage. The dented old pan I have was the original pan from my 72 T/A. No baffle.
Didn't the later model pan also have a different rear seal? Anyone got a photo of the pan baffle (next to a ruler would be perfect)...or better yet, have an extra, loose pan baffle? The original pans usually have the oil drain plug in a different spot than the later/aftermarket ones. So I am trying to look original on the outside, at least. Last edited by njsteve; 11-23-2012 at 05:20 PM. |
#645
Here's a photo of a baffled pan but it is at an angle. If someone could post a photo from directly overhead and get me some measurements, I could create one at the votech metalshop next tuesday night.
#646
I'll check later,,I MAY have one handy to photograph,etc.
On the exhaust manfold coatings.......I been pretty happy with the Bill Hirsh (brush on) coating....it looks pretty good,lasts ALONG time & can be touched up OR recoated at any point in time.....GREAT for a car you are planning on actually DRIVING...
#647
OK,here ya go!
Length appears to be 12 1/4......add another 1" or so for the back mounting tab Width " " 8" .... with mounting tabs 10"
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! Last edited by 2manyT/A'S; 11-23-2012 at 10:00 PM. |
#648
Excellent. How about the depth from the top of the mounting rail on the pan?
#649
Howzat..................?
#650
One thing you may want to do is to weld a small brace over the edgs of the clutch fork to give it some more strength. Welding it across the edges in the back to about the center will keep it from bending while in use. The brace will keep it from flexing when you push in the clutch. You can really tell the difference when you push in the clutch , it's closer to a hyd. clutch then a manual clutch because it doesn't flex anymore. As far as the paint I really do like the eastwood true Alum. paint to paint the trans & the intake. It looks natural but the grease & oil doesn't stain it the way natural alum. does. All the dirt, grease oil & about anything that splills on them after painted wipes right off, or hosed off when cleaned.
#651
Howziz?
#652
That baffle looks like it would be fairly easy to make. Is anyone reproducing them? Norwood???
#653
Steve, usually procedure for me also involves chasing all the threads on the timing cover ... IF your bored! looking good!
" Long may we DRIVE !" |
#654
Anyone have a photo of the modified fork? I want to see how long of a reinforcement you used.
#655
I dragged my 12 year old, engine building apprentice out to the garage today (it's about 38 degrees or so at the moment). I had him measure the top and second ring gaps in the cylinders. I had to keep reminding him not to "saw" the feeler gauge but gently see if it passes between the ring ends. Only had to remind him 16 times. :-)
Top gaps were .016 and second ring gaps were .020 after doing some mix and matching between the cylinders.
#656
Use the heavy duty Corvette fork.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1996 Trans Am WS6 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 |
#657
I ended up getting a McLeod 673-16931 heavy duty clutch fork to replace the stock unit with the broken tab. http://www.jegs.com/i/McLeod/673/16931/10002/-1#
I did have to do a little trimming of the flared out portion on the top edge of the fork to clear the interior bolt mounting boss. ![]() ![]()
#658
Back from shop class with the revised oil pan. Took about an hour to fabricate and weld in the baffle. Gotta love those plasma cutters. Man those things cut the labor time into seconds. It took longer to trace the template onto the steel with a magic marker than it did to cut it out with the plasma cutter. Then I used a hammer and an anvil to bend the tabs and form the lip on the interior edges.
It's not too pretty but it fits and clears the oil pump perfectly. ![]()
#659
That'll do....not like anyone at a car show is going to see it, lol.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
#660
Looks like it'll provide the functionality you're after. Just wait until someone opens that engine years down the road and sees it. We'll then hear, "My '72 Formula has a prototype oil pan on it!"
