A nitro motor needs 100-150 psi at idle at the hit or will destroy bearings. A Titan is fully adjustable and expandable. I have 3 of them. 2 of them are the expanded nitro versions. You would even set up your pan to adjust your oil pessure with the pan on should someone need that. Another application would be an endurance/marine application. My Pontiac powered jet boat ate oil pumps. They do not like high temps for long periods. If you are N/A and drag racing, I would guess the $20 pump would do the job but, I am not going backwards, will stay will my 3 Titans.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
You mean... like the setup I built into the Tri-Power engine sitting in my GMC? Melling pump with relief spring seat adjustment brought out through side of the pan; works great.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
