The Vin Stamp has a misstamp at the end. Was this common? 70 Norwood Trans AM
Yes, mis stamps are fairly common. my 77 T/A had a ghost stamp on the engine number itself where the stamper must have double tapped, and it bounced.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
Does that stamp have 29N at the front?
Yes, it begins with "29N"
This isn't the original engine for the 70 TA then?
I believe it is. Block Casting # 9799914, prefex WS 0585920
If there were inconsistencies with the engine/stampings - would you rather know them
- or would you rather Not Know Them ? Sometimes its a delicate situation for an owner. Just need to confirm your wishes before more is discussed probably. |
Nope, I'm definitely interested to verify the originality. I am not questioning anyone's authority, just trying to get it straight.
Just wanted to know how you felt about some "possible" bad news first.
29N the 2 is a Pontiac designator the 9 indicates it was an engine for a 1969 production car (you have a 70) the N indicates Norwwod plant When a double strike happens on an engine VIN at faktry - basically the whole group is restruck. They use a gang stamp holder fixture - not each number stamped individual. All characters should be in a perfect strait line with each other on each "strike". And all should share the same font and size. Restrikes can take on many appearances - heavier or lighter to one end than the other - a bit misaligned from original strike - etc... i had some sample pics but cant locate them. The next issue is that a WS would not have been instituted at Norwood in 69 Best things to do: Wipe your engine VIN area cleaner with lacquer thinner - or sand it cleaner with 180 grit sandpaper and take more pics. Get the date code from around distributor mounting hole. (B149 for example) Clean or sand your WS stamp and take some pics. Then post the pics /findings. |
THE S ON THE WS LOOKS A LITTLE WEAK
I WOULD BET MONEY THAT BLOCK IS A RESTAMP
Is the 122912 the last 6 numbers of the car's VIN?
400guy: If you've got the PHS documents for this car, you can also verify the engine unit number on the car "Billing History" form.
It should match 0585920 (or at least the last 4 digits of that number) It might show: WS5920 |
Looking through my EUN page, it appears the EUN is within range of the engine and the date code.
I'm wondering if the stamper didn't screw up the '9' along with the other digits? Does it look like a '2' under the top '2'? (looks like it may be something else) The area around the stamped VIN looks original and not ground on. Cool engine.
Just to sum this up........(if I'm reading the codes right?)
We have a 1970 400? block cast on May 19/70 in a 70 T/A vin (228870N122912) that was built in the first week of June 1970 with a block code stamp WS & partial vin of 29N122912? Is your car a survivor,restored OR basket case? Is displacement (400) cast above pan rail behind fuel pump? Has block cast # below rear of PS cyl.head been tampered with or modified?
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! Last edited by 2manyT/A'S; 12-03-2012 at 06:25 PM. |
I have the PHS invoice, but I do not see a "billing History" form
partial stamp is 29N122912
EUN won't be on any form from PHS on any car after 1968 unless you have GM of Canada documentation.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
