Old 12-03-2012, 09:04 PM
MD79TA MD79TA is offline
Default Body stripping question
Want to do body work on my 68 gto convertable. It has a few spots around the wheel on the rear quarters. I was looking into how to best strip these areas before I seek help possible from a body shop or maybe do them myself. I know that sand tends to warp,soda leaves a residue that does not like paint. Has any one heard of dustless blasting? Or should I just sand it down by hand? It has some rust and bondo and I know it is usually worst than it looks. This is a southern California car and has sat for 10 to 15 years, floor pans and trunk are original and solid. My plans are to get it running and enjoy it as I slowly fix her up. I don,t want to take it all apart and look at for the next three years as I put it back together. Thanks in advance for any help or suggestion Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 12-03-2012, 10:22 PM
hpp's Avatar
hpp hpp is offline
Might help to post a pic if you can. Angle grinder with a 2" 36 grit roloc disc will remove paint and most rust/filler. Far as rust
that is not removed sand blasting would be ok on non large flat surfaces.
Old 12-04-2012, 12:46 AM
6d7gto 6d7gto is offline
dustlessblasting.com
Old 12-04-2012, 05:05 PM
GoatDr GoatDr is offline
You shouldn't sandblast body panels, but glass bead or soda blasting is OK. I had one of my GTO's completely blasted with glass beads. It took everything off including rust and bondo. Strip the rust areas, use a rust treatment, paint with primer, either repair with new metal or bondo it again until a full repair can be made.
GoatDr
Old 12-04-2012, 06:58 PM
hpp's Avatar
hpp hpp is offline
I've never had a problem with sand blasting long as the panel is not large and flat such as a hood. I had fenders and doors and 1/4 panels sand blasted with no problems. If you have small areas that need rust removal such as a 1/4 lip sand blasting would be fine.
Soda blasting,glass beading,chemical stripping are also a great way to go.
Old 12-04-2012, 09:37 PM
Cammer-6 Cammer-6 is offline
a razor blade will make quick work of piles of paint
wont do much on rust or filler tho
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 12-05-2012, 03:15 PM
Nikwho's Avatar
Nikwho Nikwho is offline
X2 IF the person doing the blasting knows what they are doing. If the blaster you find isn't experienced in blasting car parts/panels I wouldn't go that route. I'd strip it manaully with a DA and use phosphoric acid on the rust.
'67 Tempest Custom - Resto Mod 462/TH400
'59 Chevy Apache 350/700-R4
Old 12-05-2012, 03:26 PM
hpp's Avatar
hpp hpp is offline
I've been going to the same person for a long time and thats a good point. They do need to know what they are doing.
Old 12-05-2012, 04:34 PM
What kind of tools for bodywork do you have on hand?
If I was just stripping a few small areas like you describe, I'd just get an electric, variable speed angle grinder. I like to use a wire cup on it. It won't damage the good metal.
You can have the paint off both sides in 15 minutes.
There are MANY ways to skin that cat.....or Goat, as the case may be.
Old 12-05-2012, 04:58 PM
Here are some pictures of the body. It is from california and had not been started in 15 years until this weekend. All the floor boards and trunk are solid.Just want to clean up these spots. New roof and on the road next summer for some fun.
ID:	305167   Click image for larger version
Name:	gto body 2.jpg
ID:	305168   Click image for larger version
ID:	305169   Click image for larger version
Name:	gto close up.jpg
ID:	305170   Click image for larger version
Name:	gto driver rear.jpg
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 12-05-2012, 05:03 PM
Default more pictures
Here you go
Name:	gto driver.jpg
ID:	305172   Click image for larger version
ID:	305173   Click image for larger version
Name:	gto engine.jpg
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 12-05-2012, 05:05 PM
Yeah, I'd use a variable speed grinder and use a combination of 40~80 grit discs and a wire cup when you get down to the metal. Get at least a 4" grinder. You've got some filler in there and the rust will be beyond what you think. You won't get an honest assessment until you get the paint and filler out of the way for a fairly large radius around the rust you can actually see.
Not saying it's in bad shape...actually looks pretty good but you have to bite the bullet and get the damage out in the open...as painful as it may be. lol
I'd take all the paint off both quarters myself...repair as needed and epoxy them....then you can drive it for a while until you get ready to dive into it fully.
That's just the way I would do it. There's plenty of ways to handle it.
Old 12-05-2012, 05:09 PM
Bob Scott Bob Scott is offline
You've got a good bit of rust and old bondo in those areas, I'd use a 7" sander with a 36 grit fibre disc.
Old 12-05-2012, 05:47 PM
Thanks for the info. I just took a look at the rally two wheels ' I have a set of 5 and they are JA 14x6. Are they worth anything? I will most likely change to 15 wheels. This is a disc brake car.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 12-05-2012, 06:34 PM
nytrainer's Avatar
Those wheels were used on the 68 with factory disc brakes (as opposed to JC wheels). I'd like to steal them from you and say they are worthless lol. Should get alot of interest in them. I'd be interested.
Dave
Old 12-17-2012, 07:42 PM
hobi hobi is offline
Default blast
the last 5 gtos i stripped i used aluminum oxide i would highly reccommend wont get rid of undercoating but i use walnut shells for that good luck.
Old 12-28-2012, 02:40 PM
Default Grit sand paper
Got a new National Detriot 6 inch DA sander and im ready to start stripping around those wheel wells. What grit paper should I buy. 40,60,80 thanks for the help, Don/t want to use to agressive and danage the metal if that can be done.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 12-28-2012, 04:16 PM
455GRIN 455GRIN is offline
Try 80 grit first...should remove paint quickly...keep it moving don't burn the metal
Old 12-28-2012, 06:16 PM
Why did you decide to use a DA? Just curious as I haven't had much success stripping with one. Grinder is much faster IMO. As for paper...I agree with 455GRIN. 80 is a good starting point.
Old 12-28-2012, 08:19 PM
Verdoro 68's Avatar
I started with 80 but that got a little tedious since I had two paint jobs to get through. I ended up having the best results using 40 to get through the first paint job and bodywork then using 80 to take down the factory paint to bare metal.
Ken
'74 Ventura 350
'69 AMC Javelin SST
