Ran a ad for renting a set of Proform scales, ill wait and see what happens for giggles
I don't understand why this is such a issue Rich, and why would u even beother to try and scale it that way? Its not like you are a 4 second car that needs to know where every last damn ounce goes or needs to be. You Can't tell me there isn't a place close to you that has a scale for grain etc. Geez just use 2000 as a front weight and call it good! my god
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
If it were me, i'd go with the 47140's and trim a coil to get the ride height you want, which is most likely about an 1 1/2'' lower than you are now... that will help you take advantge of what the spring will do for you... If you dont gain some total travel out of this deal, its not gonna help much... make sure the front A-arms move very freely, before you install the springs... loose is good, in this case, anyway... Most likely, either spring will do the job...Ride height, dont forget to measure where you are now, before you disassemble....
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,([email protected])1.578 60' Oct 2010!! ![]() ![]() ![]()
I'm just a little confused as why you are worried about changing front springs on a car that run 13's. There are many on this board that run low tens with all the factory stuff. Spend your money on making more power first.
Less said,,,,,,,, Less mended. |
Grain????? shoot we make steel here , lol, sorry wrong part of the country. As for why i am changing springs, no lift on my car at all, very stiff, looking to drop my 60er,s a little. Not going to change anything(motor wise) untill get car where i want it to be.
Does this english mean something different in West Virginia. Save your money and use it to make more power first. Then dial your chassis in to go faster. You build a house after the foundation has been put down, it is no different than making a car faster. The engine is the foundation, and your foundation isn't making enough power yet. Your MPH shows this. My car is 2 seconds faster than yours using the factory springs and suspension both front and rear. Changing the front springs is not going to make your car any quicker. It will make your wallet lighter, and just frustrate you even more.
I would have to agree with you on this... my bird does 1.49 60fts with 100% stock front end(springs included)... Maybe his car sits too high, taking up much of his travel... but, i think alot of his problem is in the traction/track/driving dept. Its amazing how that can greatly affect the E.T. at the end of the track...
Tin Indian yep my Englay same as yours, you like to spend money, Ill go faster the old way and earn it one tenth at a time. Anybody can throw a big dollar motor together and brag how fast it is, like nitrios big deal??? I love to watch those stockers make them look dollar machine well look slooooooow! Oh ya, again i have Poly bushings everyplace causing some issue,s again ill correct this all first.
No high dollar stuff in my motor. I even run factory cast rods. crank and use a flat tappet hydraulic cam. You could probably put the same combo together for about $3000 bucks, oil pan to carb. No nitrous, its not allowed in the NMCA class I run. I don't spend a lot of money, in fact I told you to save your money and put it into making more power. You ask questions on this board to save money, yet take no ones advise who actually have been there done that. Your MPH shows you are not making the power you think you are, the physics do not lie. Try listening and taking some of our advise, or just be happy running in the 13's.
As for the stock eliminator cars you watch. Do some research before you post. They have mad money in their combinations to be competitive.
Ive listened to everyone,s advice i believe, but i will make sure no fly by nite specialist try,s to talk me into something. I keep hearing my combo should go 12.80,s but im going 13.20,s so what advice do i get,?? switch cam or another convertor, shoot mine works just fine. I am switching a couple things around, new plug wire,s, trying a stock intake over my RPM. Also switching axles for safety sake and trying to loosen up the front end a tad. Distributor sent out recalculated no improvemant. I am hearing bigger tube headers, as soon as my front end is completed it will be the last change or now. My biggest decision will be head work next. Stay tuned to see whats next!!
Rich, he's right about pretty much everything...Im just saying that your MPH is telling the story... 98mph is showing that the horsepower is way low... your stuff should be making somewhere around 350-370hp...but for some reason, its not doing it... I dont think its a matter of changing parts , to get it... its gotta be in the tuning, or assembly, or condition of the parts that you have. And, yes, the NHRA Stockers , that run extremely well, have more money in their engines, than i do in my whole car... i guarantee that... I would love to know where your HP is hiding... its in there, somewhere....
Ok, silly question here. Are you having traction issues? May bee I missed it earlier in the thread.
Brian Rock '65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs. 9.88 @ 134 N/A on Cali 91 octane. http://www.youtube.com/watch?v=NJEIY5OJ68g
MPH tells the story to run in the 12.80's, you need to be around 102-103 mph is my guess to hit that E.T. MY bone stock 70 GTO (which is nothing more than a show car) runs 98.2 mph in the qtr with its original 400. Figure out the mph first then mess with the other stuff.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
Believe me guys i know and wish i can get it to 102or3 mph. I am told by alot of racers a hydralic cam slows you down like big time but to be truthfull i like the low maintanance issue. Now im not lazy but i love starting the car driving it on the trailer take it off and if i had to drive it home. My Grower cam 60916 with 1.5 rockers MAY be the issue here. Also i personally fill my car shoots straight out without spinning as far as i can tell. I have adj. upper arms in back and boxed lowers with air bags no air. Lobe separation is 112 degree,s.
I really want to change my headers after my new axles come in and new 90/10 shocks are on the car. Im open for ideas and thoughts and read them all. Rich |
I don't know anything about how your car is set up, but I ran in the low 13's (about 105 mph) with pretty stock stuff. I ran in the high 12's (about 108 mph) with cast iron manifolds, a hydraulic cam (744) and 3.90 gears. All of the suspension was stock except the shocks. I ran 70/30's or 45/55's on the front, and 50/50's on the rear. I still have the original factory springs in the car to this day. If everything else in your car is setup right (gears, fuel system, etc.), then my guess would be that your cam didn't get installed at 108 (advanced 4 degrees)
Mr. Taylor, bare with me ok, i installed cam stright up with a cloyles timing set , can you help with a brief explanation on how its done??? Maybe ill go to Race section and ask for help with that.
#38
You can never be sure how the cam is oriented unless you actually degree it. Some are right on, and some are way off. It's harder to degree it with the engine assembled, but it is possible. It takes a few special tools. If you've never done it before then it would be best to have someone do it who has some experience at it.
#39
#40
Crower cams are known to be way off!, I would degree it to find out where its at.
