Ponjon not many E85 stations around here
Dished pistons.You should not need 39 degrees timing,Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
Bill, I know I should not need 39 degrees but that's where it ended up. I think that the compression is too low with the 30 cc dish pistons and 72 cc heads. Maybe I should just put a blower on it.
What RPM was peak power?
Any more specifics on your intake? runner CSA @ head, CSA @ plenum, runner length, plenum volume? how much lift at the valve? |
Pastry, the intake was designed to fit under the hood. I matched the head port openings and kept the runners the same dimension all the way. I was recommended to do this by another porter. I do not know the plenum volumn but the runners are 2 7/8 x 1 3/8 to match the port opening. I really DO NOT want to cut the super 400 hood that is on it for a taller intake unless it can be proven to vastly outperform this one.The valve lift is .800. Hopefully I can post the dyno sheet and pics of the intake.
Also bare in mind that the above dyno sheet is a chassis dyno.
