Old 01-01-2013, 10:26 AM
cnc's Avatar
cnc cnc is offline
Default 1973 Nose support bushings ??
I need to change out the front two bushings in the frt nose of the car the passenger side is seperating so gonna do both
not exactly sure what there called anyone have a Part # for reference or personal experience with them .....thanks...Chris
Name:	2013-01-01 09.18.58.jpg
ID:	307863   Click image for larger version
Name:	2013-01-01 09.37.57.jpg
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 01-01-2013, 10:31 AM
77 Canamman's Avatar
PY also sells them for $145 and has them in stock, PN RFF17C.
from another thread..
http://forums.maxperformanceinc.com/...05#post4078805
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-01-2013, 10:46 AM
cnc's Avatar
cnc cnc is offline
Thanks 77canamman....
I " thought " those were them but just wanting to be safe ...thanks Chris
Old 01-01-2013, 01:53 PM
Those are pricey, but at least they are produced!
Old 01-01-2013, 02:49 PM
Greenbird76's Avatar
Greenbird76 Greenbird76 is offline
OER makes them too and I got them for my 76 for around 25$ a piece 2 years ago. Many vendors sell them. Here is one I quickly looked up online for your 73. It is the same for 76-
http://www.carpartsdiscount.com/auto...html?3594=1950
Lean, Mean and GREEN
Old 01-01-2013, 03:13 PM
Held for Ransom's Avatar
'73 is different than the '74 or '75-6 unit (which your link suggests by PN).
Old 01-01-2013, 03:41 PM
cnc's Avatar
cnc cnc is offline
Yep I saw the ones from OER but it states they are 67-76 ( classic Industries) and 73 is apparently different
I'm gonna get the ones from PY cause I want to make the frt sheetmetal alignment correct once I get the new hood on....Thanks for the help ...Chris
Old 01-02-2013, 11:22 AM
Yup sorry about that, just trying add input. Just by looking at your pictures, I can tell that the 73 bushings are wider than the ones on my 76. If you are trying to keep your car as original as possible, then the PY ones seem to be your only choice.
However, for those that are on a tight budget and can't afford the $125 a piece price tag, I see no reason why not to try the OER piece. If the bushing material and studs are the correct length, I bet the piece would work. It would not look correct to the trained eye, but would function the same.
Ron.
Old 01-05-2013, 04:16 PM
form74's Avatar
form74 form74 is offline
Here's a few shots of some that I purchased at a dealer in March 05, are these correct for a 74.
GM PN 00498951
ID:	308416   Click image for larger version
ID:	308417   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 01-05-2013, 06:13 PM
Gary, those are the '75-6 units.
http://www.forums.maxperformanceinc....d.php?t=557470
Old 01-05-2013, 07:55 PM
cnc's Avatar
cnc cnc is offline
GM PN 00498951
Thanks for lookin Gary....just checkin with Py to see if they have some...Thanks HFR for clarifying this....Chris
Old 01-06-2013, 12:11 AM
form74's Avatar
Mike, thanks for info and the link, as usual your a great source of information.
Chris, No problem, seems I have the wrong ones for my car also
Old 01-06-2013, 03:49 AM
Don't get me wrong. The bushings may be wrong as far as studs thread size/length or OD size of bushing, but still may be good enough to work.
Old 01-06-2013, 09:18 AM
cnc's Avatar
cnc cnc is offline
Well if im gonna change them out i want the Correct ones,,,,,
Thats Sucks Gary...hopefully not tooo much to change them out...
