| The Body Shop TECH General questions that don't fit in any other forum |
I need to change out the front two bushings in the frt nose of the car the passenger side is seperating so gonna do both
not exactly sure what there called anyone have a Part # for reference or personal experience with them .....thanks...Chris
http://forums.maxperformanceinc.com/...05#post4078805
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
Thanks 77canamman....
I " thought " those were them but just wanting to be safe ...thanks Chris
Those are pricey, but at least they are produced!
OER makes them too and I got them for my 76 for around 25$ a piece 2 years ago. Many vendors sell them. Here is one I quickly looked up online for your 73. It is the same for 76-
http://www.carpartsdiscount.com/auto...html?3594=1950
Lean, Mean and GREEN |
Yep I saw the ones from OER but it states they are 67-76 ( classic Industries) and 73 is apparently different
I'm gonna get the ones from PY cause I want to make the frt sheetmetal alignment correct once I get the new hood on....Thanks for the help ...Chris
However, for those that are on a tight budget and can't afford the $125 a piece price tag, I see no reason why not to try the OER piece. If the bushing material and studs are the correct length, I bet the piece would work. It would not look correct to the trained eye, but would function the same. Ron.
Here's a few shots of some that I purchased at a dealer in March 05, are these correct for a 74.
GM PN 00498951
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
Gary, those are the '75-6 units.
http://www.forums.maxperformanceinc....d.php?t=557470 |
Thanks for lookin Gary....just checkin with Py to see if they have some...Thanks HFR for clarifying this....Chris
![]() Quote:
Don't get me wrong. The bushings may be wrong as far as studs thread size/length or OD size of bushing, but still may be good enough to work.
Well if im gonna change them out i want the Correct ones,,,,,
Thats Sucks Gary...hopefully not tooo much to change them out...
