| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
What this car has must be the waste gate, its mounted down under the engine on the exhaust system. I only looked at for a minute or two. It has a small hose running to it, right dead center of the top. I assume the boost pressure opens this at a set point. Is it adjustable? The whole top seemed to rotate but it could just be loose or defective.
So if I understand this right, the waste gate controls the exhaust going to the turbo. As boost comes up the waste gate opens at a pre set pressure thus dumping excess exhaust away from the turbo. This seems like a good choice as the turbo would not need to work any harder then needed. A blow off valve is on the clean side of the turbo and acts like a pre set pop off valve. Once it opens, the turbo can still wind up due to the excess exhaust build up in the system thus over speeding the turbo shaft. Does the turbo know the blow off is open? or does it continue building boost only to have the blow off dumping the excess away? I can see how it would limit the amount to the engine, but it seems a funny way of doing it. Thanks for the lessons, Joe |
Plumbing wastegates with manual boost controller to set boost: http://www.tialmedia.com/documents/w..._wginstall.pdf Plumbing Blowoff valves: http://www.tialmedia.com/documents/w...bovinstall.pdf Should give you some more ideas. This is how my AWD Talon is setup, except I run a pair of wastegates instead of one.
Panos Little Miss G Racing on Youtube |
