Old 10-11-2011, 11:27 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Default AaaRrgg!!!! Heater core!!!
Came out today to find a puddle of green under the car. The 2 year old NOS Harrison heater core is leaking!!! Coolant running down between the heater box & the firewall. Am going to bypass it till I get the time to pull it apart & see whats up!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 10-11-2011, 11:43 PM
ahnuld's Avatar
ahnuld ahnuld is offline
i thought you didn't need heat in arizona.
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
Old 10-12-2011, 12:08 AM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
That sux.. are the clamps inside the box or outside?
Old 10-12-2011, 12:12 AM
In the winter after a storm front has gone over, it clears off & the temps can drop 30 degrees in one day. Lots of low 30's-40's here in the valley. BUT, I dont stay just in Phx during the winter. I do go up to the high country & have lots of drive time in the snow with this car.
Keith Collier
Tech advisor
POCI.org
Old 10-12-2011, 12:15 AM
Outside clamps.. Just ticks me off that the high dollar NOS is leaking. Once I get it out, will take it to the shop that built my radiator last year. Have it checked out/repaired/rebuilt. May not be the core. The hot water valve is inside of the heater box. That could be leaking also.
Keith Collier
Tech advisor
POCI.org
Old 10-12-2011, 01:25 AM
ahnuld's Avatar
i didn't think it got that cold there, 30 f is like summer here.
Old 10-12-2011, 01:42 AM
Arizona can pull down the high & low temp for the continental US on the same day.
Lots of times it can be in the 70's in the Phoenix area & 200 miles away in the White Mountains it will be 30 below!!! Can go swimming in the back yard pool in the morning, drive north 2 hours & play in the snow till afternoon & drive back home & go swimming again.
Keith Collier
Tech advisor
POCI.org
Old 10-12-2011, 09:48 AM
GaryK's Avatar
GaryK GaryK is offline
My NOS heater core needed to have the inlet tube soldered.
Old 10-12-2011, 03:47 PM
Gary, I looked it over real good before installing it. Also put in a NOS water valve at the same time. Got to be one or the other. Either way the box has to come out. Need to get it done before it really cools off.
Keith Collier
Tech advisor
POCI.org
Old 01-13-2013, 11:14 PM
Bringing this back up!!! After getting my core repaired last winter, there have been no issues,,,,till this morning!!! Very cold today, in the mid to low 20's!! Left early to have breakfast with some club friends. Driving down the road & glanced in the mirror. Saw a big spiral of smoke behind me!!! Quickly pulled over to check things out. Motor was running fine. Looked under the hood to find coolant running down again all over the hot exhaust! Topped off the radiator & left the cap loose & continued on. When I got home, I bypassed the core again & pulled the heater box out. The core split right down the end of the core tank, maybe 3 inches!! I know I had a good mix of antifreexe in it. Fresh from a flush & new T stat just a couple of weeks ago. So, made a temporary block off plate & am going tomorrow after work to turn in the core & get another one made. Never fails!!! Going to be a cold drive to work tomorrow!! Going to be even colder Monday & Tuesday than today!!!!
Keith Collier
Tech advisor
POCI.org
Old 01-14-2013, 12:56 AM
blueghoast's Avatar
Keith I bought a heater core for a 74 chevy truck.
The lenth was the same but the width+height was
A little smaller. And I had to make a differant hole
for one of the tubes. It's alluminium and was only
$37.00 shiped to my door. I eliminated the little
conootin valve thingy. Just a thought. I have the
part number to if you want it.
GT.
Old 01-14-2013, 03:29 PM
63 tempest's Avatar
63 tempest 63 tempest is offline
Look for a 1984 s10 heater core its d same size for a 63 temp or lemans not shored if 62 is d same as 63
Old 01-14-2013, 06:44 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
I've got one you might try if you get stuck.
Old 01-14-2013, 06:59 PM
Well,,, my parts book shows different numbers for the 61 & 62 heater cores. I will know tomorrow if they can fix this one or make another. Was awfully cold this morning on the way to work!
Keith Collier
Tech advisor
POCI.org
Old 01-14-2013, 07:14 PM
63Banshee's Avatar
They are different. I've got one in a low mileage 61 car. Not being used in 5 years can be an issue, but might be worth a try.
Old 01-14-2013, 07:54 PM
indymanjoe's Avatar
When did you start selling real estate? LOL i wanna move now...
I am the Thread Killer!
Old 01-14-2013, 08:42 PM
Sirrotica's Avatar
Keith, I was doing some reading and the green coolant can get acidic when in a system with a hot water control valve as it sits and gets stagnant. It went on to say that not only does the stagnant coolant cause leaks it also causes boiler scale inside the heater cores prematurely. It said that was why the newer vehicles don't have them, the engineers figured that the coolant was better left to circulate so the heater cores lasted longer.
The piece said that 2 other things can cause this phenomenon called silicate drop out is hard water being added to the coolant, and too high of a concentration of antifreeze, over 50%. They suggested using distilled water to mix with the antifreeze and said that even if the PH testing was good it can still happen. The article said coolant should be changed at a minimum of every 2 years and where it's subjected to heat extremes even sooner. I'm not sure if this may apply to you or not, just something I learned and thought I'd pass it along.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-14-2013, 09:39 PM
GaryK's Avatar
I too have a couple used 61 complete heater assemblies and some 63's if you want to change it over.
Old 01-15-2013, 06:57 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
AWFULLY COLD !!!! LOL !!!!
Old 01-15-2013, 07:03 PM
Mid-20's is cold,,,when you are used to the 70's this time of year!! Heat pump went out in the house. No $$$ to get it fix's yet. Was in the 30's in the house when I got up this morning!!
Keith Collier
Tech advisor
POCI.org
