Old 02-12-2012, 09:28 PM
mechanic17 mechanic17 is offline
Yes, the 90s wagons are wider than the sedans by about 4" I believe. If you were to cut two inches off each axle tube, push it in and re-weld it to the center section, you could use sedan axles and it would bolt in a sedan with the same geometry, is my theory. I will be testing it this summer.
As for compatability with earlier sedans, I have no idea about that.
Old 10-28-2012, 09:08 PM
monzaz's Avatar
monzaz monzaz is offline
Default swap rears
Well one thing you have to remember here is that your all looking at width and forgetting about the shock mounts and how wide all the other lower control arm geometry will be off too. I guess if your car will only be tooling around the streets at no more that 40 MPH and never hit a corner at over those speeds you will be fine... lol.
All these components need to be in the same locations for Pinion angles to be correct and rear end suspension and articulation work correctly.
The 1965-1970 Pontiac rear is a very good alternative with the Fab Craft gears 3.55 installed. That rear will handle all your power up to 11 sec range...beyond that you will have to watch for the posi unit to start spitting spider gears out.
I have worked with Brad at Fabcraft on other rear end projects and his gears are top notch quality USA gears. Here is a rear that we have that is the 10 bolt cover 12 bolt ring 8.875 1965-1970. Fabcraft 3.55 gears installed.
The upper control arms are ALWAYS the hurdle in the GM rears as they aRE cast IN and require a spherical rod end and adjust control arms - we sell these to help install and swap GM rear into other year GM rears...
IE We do G-body swaps with 73-77 8.5 centers and change over all the rest of the lower and spring perches and narrow them to the same width with the Custom upper controls arms... We do this with 8.8 LTD centers and 12 bolt chevy rears too. It WORKS great.
We just never had as much interest from anyone coming at us for FULL SIZE cars. It seems to always come down to the money... One way or another you will have to spend some money to get a stronger rear with more selection of parts.
We are working on a GM 14 Bolt 9.5 3/4 ton truck housing to solve the super power needs of the 800+HP cars. It is Slow going as we have to fit it in between all the regular BILL PAYING orders and parts. Jim JD
ID:	301714   Click image for larger version
ID:	301715   Click image for larger version
ID:	301716   Click image for larger version
Jim Mitschke
J D Race and Restoration
Richfield, Oh
[email protected]
Old 11-06-2012, 03:47 PM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Thumbs up
Is Fabcraft looking at producing tougher spider and axle gears to compliment their new 3.55s for the 65-70 fullsize rear? I would be interested...currently running Brad's 3.55s on a 1972 2-series posi...I'm turning up the heat to 650 HP soon, and the spiders worry me.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 01-20-2013, 09:03 PM
monzaz's Avatar
Default spiders
As far as I know that is it for the 65-70 Pontiac rear. It will not get anymore attention.
This is why I am trying to come up with a complete NEW rear.
10 bolt 8.5 is ok if your going to drive the car around on the street and do burn outs...BUT if you put the power to the geround at the track...FORGET IT the 8.5 in that big car will blow the small spider gears right out.
If you do not use a FULL SPOOL with that weight your doomed.
This is why I am working on the 14 bolt GM custom rear. This GM rear is the same size as a DANA 60. BUT ALL GM.
We do camaro rears and 55-57 chevy rears from these. BUT they are easy because they are all LEAF SPRING set-ups. Jim
ID:	310386   Click image for larger version
ID:	310387   Click image for larger version
ID:	310388   Click image for larger version
Jim Mitschke
Richfield, Oh
[email protected]
Old 01-22-2013, 11:33 AM
AROWHED's Avatar
Would deep freeze treatment of the spiders and axle gears be any benefit?
Old 10-15-2025, 10:40 PM
FullHawgPoncho FullHawgPoncho is offline
Originally Posted by Rapdron View Post
I have a 3.42 posi rear out of my 66 Bonneville at my shop.
I will be there later this morning, and will take smoe measurements
Ron
Do you have any rear ends for sale? Looking for one like that for my 66 gp.
