Additional Parameters:
455 + .040, SD Performance heads (250 CFM), Crower 60919 cam, 1.65 rolling rockers, 9.25:1 compression, fed by a 1965 Tripower, no mods to that or the intake. No clue what the jet size is right now. Was running rich at sea level though. Dinosaur fuel, 92 octane. |
Also, do you have enough vacuum to keep the power valve closed other than WOT. An open power valve would cause the unit to be rich, and could confuse the selection of the jet size. Since we don't suggest the small center of the 1965 on a 455 period, I don't have a suggestion for it. In addition to changing spark plugs, I would go for a good ignition tune-up. Jon.
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
