Old 01-20-2012, 09:51 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
The current owners cranked up the heat for the inspection and it was great even warmth.It took a little time to get the temp up from the 48 degrees they keep it at but no big deal.
Thanks for the advise/comments!!
Old 01-21-2012, 09:03 AM
67drake's Avatar
67drake 67drake is offline
If you buy this house,I bet you'll love this set up.
Like I said I wish my current house had it.
‘55 Catalina
Old 01-21-2012, 10:03 AM
judgethis judgethis is offline
Ive got the heated floor in my garage and its wonderful. The heat source needs to be changed as its using a 30 gal electric water tank. But the warmth is awesome. I can open the garage door to pull the car in or out and then shut the door and it still feels warm. If I ever build a house ill have heated floors in it. Of course Ill probably never build my own house.
Old 01-21-2012, 10:19 AM
Blue '66's Avatar
We have not bought it yet but everything is the progressing along.
Old 01-21-2012, 07:41 PM
blue goats's Avatar
blue goats blue goats is offline
Something also great about baseboard heat. Very little dusting tables ,tv's etc.My wife wishes we had in our new house . You don't miss it till you don't have it.
George
Old 01-24-2012, 08:18 PM
drailed drailed is offline
I grew up with forced hot air and dont miss it one bit. No waking up with dried out sinuses and itchy eyes. 2nd best thing to radiant floor heat. You will like the hot water baseboard.
Old 01-24-2012, 08:33 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
baseboard heat is better then central air any day. But radiant floor heat Just rocks. Spent this last fall converting my house to radiant floor heat.It is just awsome. warm floors.even heat thruout. Dont have to worry about blocking the radiators. Definitly the way to go if you can. Then for the summer time we installed a pair of ductless A/c units upstairs. (live in a bi level) they cool the house down nicly.
Old 01-26-2012, 01:19 AM
Formulabruce's Avatar
Only drawback as you saw with baseboard is its slow. wel-Mclain is excellent quality.
keep the burner tuned and youll be all set
" Long may we DRIVE !"
Old 02-18-2012, 09:54 PM
Blue '66's Avatar
Default New questions?
Will the baseboard heat work in a power outage?(Since there is no blower)
We are supposed to close on the house tuesday!It has taken longer than we thought.
Old 02-18-2012, 10:23 PM
Ed Fitzgerald Ed Fitzgerald is offline
Default 5000 watt generator
Buy yourself a 5000 watt generator and have it ready for extended power outages. Have it wired into the panel. You will need to power the boiler and pumps anyway or you won't get any heat anyways. Boiler and pumps won't take much draw and you should be able to run the fans and a few lights.
Old 02-19-2012, 08:44 PM
Blue '66's Avatar
I didn't think about the pump!
Old 01-21-2013, 05:42 PM
Blue '66's Avatar
Default update
My boiler went out,great timing!We are going to have some of the coldest temps so far
We had a fireplace insert installed for backup heat.
The heating guy tells me our furnace was about 70% effecent,I want to get one at least 90% to replace it.Now I have to wait to see how much $$ and how long it will take to get the boiler.......
Old 01-21-2013, 06:24 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Interesting thread. I don't have anything to contribute but sounds like some good information in it.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 01-21-2013, 06:37 PM
george kujanski's Avatar
Our previous house had radiator heat. Yep, it's even, not a blast of warm air like forced air.
Downside is adding A/C and humidity during the heating season.
George
Old 01-21-2013, 06:55 PM
zeebo's Avatar
zeebo zeebo is offline
not a fan of electric heat or base board heat. you cannot have central air in a house with base board heat, and temperature regualtion is not precise--either volcano heat or ice cold. get a new high efficiency forced air furnace, and central air and youll be good to go.
Old 01-21-2013, 07:48 PM
Blue '66's Avatar
George
Lucky for us they did add A/C.The humidity level now is alot higher than the last house we rented with forced air.
Old 01-21-2013, 07:56 PM
indymanjoe's Avatar
I know nothing of electric heat.Baseboard is not ice cold or volcano hot.maybe with a system that has never been maintained,zoned improperly,filthy radiators..or a t-stat on an uninsulated wall?If my next house has forced air it will be removed and a boiler installed.wife can go 2months without dusting alone,and its a constant warmth.and yes you can have A/C with a space pak system.
I am the Thread Killer!
  #38
Old 01-21-2013, 08:18 PM
Default Boilers
Blue, I wish you were closer to me or better still right next door I could cure your heating problem with my outdoor wood boiler. I put about a wheel barrow load of wood in it once a day and forget about it. My shop is 26x40 with 16 ft ceilings- 2 14'x14' overhead doors and a man door. It also has 5- 4'x4' fixed unit thermo pane windows. It has been about 5* below zero F for the last few days and supposed to stay that way for the next week or two. I have infloor heat and the building is ICF. I turned the mixing unit back again today as the wall thermometer is reading 80* F. I want it around 60* F as I have some work to do in the next few days. Right now I'm off to flood the out door rink I built my 13 yr old.Ed
  #39
Old 01-21-2013, 09:18 PM
Cammer-6 Cammer-6 is offline
Heat is working fine here too
shorts and t shirt all day outside
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #40
Old 01-21-2013, 10:13 PM
zeebo's Avatar
with forced air you can have almost instant heat/cold..and it circulates the air and you can add a humidifier to it. i have had base board heat in my apt for 14yrs...takes a lot longer to warm up and you cant regulate the temp very well with just a valve on the inlet pipe...maybe some systems operate better than in my bldg, but mine leaves a lot to be desired....
