Old 01-23-2013, 07:36 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by jdw_poncho View Post
If your steering wheel is removable I think you'll be ok. That car will be low enough that you should be able to step right in.
I angled my cage back just a touch and I cant remove my stock steering wheel. Im 280 and can pop right in. But I need the window down in the door to get out. I dont have anything to hang onto when I pull myself out.
The worst thing I had to overcome was turning the damn master switch on before I get in the car!
Looks good! But when its 100 degrees out you'll wish you had a 8.50 car with a swing out door bar!! LOL
The steering wheel will be removable and I’m going to try to keep my weight under control. Can you get a wireless remote for the master switch?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 01-23-2013, 10:41 PM
A remote activation could be done with remote door lock solenoid(s) as long as its setup to allow the manual kill to work as intended.
