Old 01-26-2013, 07:19 PM
dda72's Avatar
dda72 dda72 is offline
Pic from Qualifying
Name:	JS in FL.jpg
Old 01-26-2013, 07:28 PM
dda72's Avatar
Another pic
Name:	JS in FL 2.jpg
Old 01-26-2013, 09:44 PM
dda72's Avatar
1 more.
Name:	JS in FL 3.jpg
Old 01-27-2013, 12:35 AM
john marcella john marcella is offline
What does a Pontiac got to weigh NA Ultra Street?
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 01-27-2013, 12:46 AM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
2950 NA, 3200 BOP N2O
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot
72 LeMans "POS" - Next US beast
Old 01-27-2013, 01:31 AM
R 70 Judge's Avatar
This is an 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. X275 is a qualified quick 8 field. Courtesy staging and auto-start is in effect. There will also be another class called “The Shootout” for qualifiers #9-16, and it will be run on a pro ladder. This allows non-qualifiers to compete for additional points and a place to race. (At larger events 2 – 16 or 3 – 8 or 3 -16 car fields or all-run format may be used)
SAFETY:
All NHRA/IHRA and Local Track Safety rules apply for driver and car, including the use of an oil retention device or engine diaper.
BODY:
The car must retain its original appearance, profiles, and dimensions. Factory roof and quarter panels must be used. Aftermarket fiberglass and/or carbon fiber replacement panels are limited to hood, front fenders, doors, deck-lids, and bumpers only. All front ends must be of factory dimensions and cannot be stretched. Aftermarket wings and spoilers are permitted. Complete stock appearing front and rear bumpers are required. A hood must be used: scoop or hood must cover the entire induction system. Forward facing hood scoops/ turbo or supercharger inlets are permitted. Beam trippers, extenders prohibited.
INTERIOR:
Factory appearing dashboard, door panels, and driver seat is required. Full Carpet is required on floorboards including transmission tunnel. Factory floor pan on driver and passenger side required. Transmission tunnel maybe removable and must be metal. Bare inside frame of car cannot be exposed. Aftermarket steering column is permitted.
WINDSHIELD/WINDOWS:
OEM glass or lexan windows are permitted.
CHASSIS:
Complete stock chassis and frame rails must be retained from motor plate/shock tower to behind the rear wheel opening. Back-halved cars are not permitted. Front core support may be modified or removed. Aftermarket bolt-on replacement front K-members/sub frames are allowed (if front shocks bolt to K-member then they must be in factory location). Mini tubs are allowed. Rear frame rails may be notched for clearance and must be in the factory location. Factory wheelbase must be maintained. (+ or – 1 inch)
ENGINE:
Maximum displacement for all engines is 588ci. Small blocks are allowed any deck height but must retain stock bore spacing. Big block allowed the following deck heights but must retain stock bore spacing. GM Big Blocks are limited to a 10.2 deck height. Ford Big Blocks are limited to a 10.3 deck height. Mopar Big Blocks are limited to a 10.7 deck height
TURBOCHARGERS:
Single turbocharger limited to 88 mm maximum. (GT55-88, Pro-Mod 88, ET-R88, Comp, Bullseye or = mid/large frame turbo). Turbocharger size will be verified by measuring the housing bore at the leading edge of the impeller wheel and must maintain the contour of the compressor housing. Inducer dimensions will not exceed 3.462 inches and Exducer dimensions will not exceed 4.765 inches on MID FRAME turbos. Inducer dimensions will not exceed 3.462 inches and Exducer dimensions will not exceed 5.56 inches on LARGE FRAME turbos. The maximum diameter of the housing bore at the leading edge of the wheel may not exceed 2 mm more than the maximum allowable turbocharger size permitted and LF 85/88 with surge slots/holes must have a cover over the slots/holes that stand off by no more than .250. Inserts or reducers to achieve inlet or outlet dimensions prohibited. Any type of air to air or water to air intercooler permitted. Turbochargers w/nitrous-oxide prohibited except on 2-rotor, 4 cylinder, and inline 6 cylinder engines.
SUPERCHARGERS:
Cog or gear driven superchargers are permitted, must meet all factory inlet, outlet, and internal housing dimensions. Inserts or reducers to achieve inlet or outlet dimensions prohibited. Any type intercooler is permitted. Supercharger cannot be combined with nitrous oxide. Roots superchargers are limited to a 10-71. Centrifugal superchargers are permitted. Screw superchargers are not permitted.
NITROUS OXIDE:
Small block is permitted to run any type multi-stage nitrous systems. Big blocks are limited to a single stage nitrous system with single -6 line(**see below for accepted line) to fogger single wye to -4 line(**see below for accepted line) connected to fogger solenoids or single -6 line (** see below for accepted line) to plate solenoid(s) – A single stage fogger (2 nitrous solenoids and 2 fuel solenoids) are permitted or if using a single plate then your limited to (1 fuel solenoid, 1 nitrous solenoid), and 1 purge solenoid, purge must exit engine compartment. EFI Big Blocks will only be allowed 2 nitrous solenoids for a dry nitrous system and will only have 1 line per nozzle/per cylinder. (Using both sides of the fogger nozzle on a dry EFI NOS BB combo are prohibited)
TRANSMISSION:
Any factory style automatic transmission allowed. OEM factory style manual transmission allowed. Bruno-Lenco transmissions are prohibited. Aftermarket clutchless manual transmission and clutch assisted manual transmissions are permitted on naturally aspirated combinations only. Electric shifters or air shifters are permitted.
INDUCTION:
Small Block combinations may run any type induction. Big Block combinations are limited to a dedicated single opening cast intake with a single carb or a single 4150 or 4500 series throttle body. (4 blade, dual blade or single blade throttle body permitted).
OILING SYSTEM:
Dry sump oiling systems are permitted on all cars.
EXHAUST:
Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders but must not affect timing or staging beams.
FUEL:
Gasoline only is permitted. Alcohol/E85 permitted on roots blown/V6/Inline-6/4cyl applications. Alcohol or E-85 or other derivatives is prohibited on all other combinations. Water or meth injection prohibited.
STREET EQUIPMENT:
Functional headlights, taillights and brake lights required. All headlights, brake lights, etc. must be on car and not removed for any reason. All vehicles may be towed back from their passes.
SUSPENSION:
Stock style or ladder bar suspension cars only. Aftermarket four links are prohibited on all cars. Aftermarket direct replacement components such as: front control arms, rear control arms, front coil over shocks, and rear coil over shocks are permitted. Aftermarket rack and pinion steering allowed. Rear leaf springs, springs, shocks, and coil-overs may be moved to accommodate tire clearance, and do not need to be mounted in stock location. Bolt-on or welded sub-frame connectors, rear sway bars, are permitted on all cars. Wheelie bars are prohibited on all cars. Torque arms are only permitted on cars that were originally equipped from factory with it. Upper and Lower control arms must be mounted in the factory chassis locations -S Box permitted
TIRES:
All cars with power adder must compete on a Drag Radial type tire with the following sidewall designation 275/60/15. Naturally aspirated cars are permitted to run a 28.0″ x 10.5″ slick, no “W” tires permitted.
Minimum base Weights:
All minimum weights include the driver.
Naturally Aspirated (small block) 2500 lbs
Naturally Aspirated (big block) 2700 lbs
Nitrous (small block) 2850 lbs
Nitrous (big block single stage plate any deck height & conventional heads) 3200 lbs
Nitrous (big block single stage fogger standard deck height & conventional heads) 3250 lbs
Nitrous (big block single stage fogger with tall deck height and conventional head) 3350 lbs
Single YSI / F1A/6-71 Supercharger (small block) 2950 lbs
Single F1C/8-71 Supercharger (small block) 3050 lbs
Single F1R/Xi/10-71 Supercharger (small block – *mod motor or with stock valve angle heads) 3250 lbs
Single F1R/Xi/10-71 Supercharger (small block) 3300 lbs
Single F1X/XB105 Supercharger (small Block – *mod motor or with stock valve angle heads cast head only) 3400 lbs
Single 76mm T6 Turbocharger (mid frame) (small block) 2700 lbs.
Single 80mm T6 Turbocharger (mid frame) (small block) 2800 lbs.
Single 85mm T6 Turbocharger (mid frame) (small block) 2900 lbs.
Single 88mm T6 Turbocharger (Y2K or GT47-88 ) (mid-frame) (small block) 3000 lbs
Single 85mm T6 Turbocharger (Pro Mod 85) (mid frame)(small block) 3050 lbs
Single 88mm T6 Turbocharger (GT55-88, Pro Mod 88 or =) (small block) 3100 lbs
Single 85mm T6 Turbocharger (Large Frame 85) (small block – mod motor or stock valve angle cast head only) 3200 lbs
Single 85mm T6 Turbocharger (Large Frame 85) (small block) 3250 lbs
Single 88mm T6 Turbocharger (Large Frame 88 ) (small block – mod motor or stock valve angle cast head only) 3300 lbs
Single 88mm T6 Turbocharger (Large Frame 88 ) (small block cast head only) 3350 lbs
* Small Blocks (NOS & N/A) with single 4150 carb/throttle body: deduct 50lbs
*Small Block (NOS) with any plate nitrous system: deduct 50lbs
* Small Blocks (NOS & N/A) with 23 degree Chevy heads, 20 degree Ford heads, and 18 degree Mopar heads: deduct 100 lbs.
* Small Blocks (NOS only) 18–10 degree valve angle inline head: deduct 50 lbs
* Small Blocks (NOS only) cast t-ram/sheet metal/2 carbs or 2 throttle bodies: add 100 lbs
* Non-Intercooled boosted cars on gasoline: deduct 50 lbs
* Belt driven centrifugal superchargers: deduct 50lbs
* Sheetmetal or cast ram type intake on boosted/blown combo: add 50 lbs.
*Billet heads permitted, billet blocks not permitted (add 50 lbs for billet head)
* Aftermarket rear suspension COPO Chevy and Drag Pack permitted on the new Camaro and Challengers must be mounted in exact factory location on body/frame. Torque arm on late model GTO. Corvette with any leaf spring suspension permitted.
* Buick/Olds/Pontiac Nitrous combos will be 3150 lbs and not to exceed 588 cu inches
* V-6/Inline 6/4 cylinder Turbocharged/Supercharged/Nitrous combos will deduct 200 lbs from base weight on gas and 100 lbs. if on alcohol.
*Factory IRS deduct 50 lbs
**-6 and -4 nitrous line(s) must be of standard braided line construction, (high pressure hydraulic line prohibited as they exceed the internal diameter of industry standard) Standard spec lines only.
If one combination appears to have an advantage rules may be changed at the race director’s discretion in order to keep a level playing field for all competitors
Found this on the X275 website
James
1970 Trans Am
Old 01-27-2013, 02:48 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I quit reading (and walk away...) when I see that rules contain the phrases "small block" and "big block".
Old 01-27-2013, 09:56 AM
Those are X275 rules, not Ultra Street.
Old 01-27-2013, 02:06 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Yeah, you run into that in classes that are not Pontiac only...
Originally Posted by Scott Roberts View Post
According to the rules posted, a Pontiac has to be 250lbs heavier then a BBC N/A?
In x275, yes, because the weights listed a Pontiac combination would be using nitrous, probably via a fogger.
Yes, the rules posted are x275 rules, that class runs in the 4.60-4.80 range. These are the ultra street rules:
Ultra Street Shootout
1/8th mile Eliminator
BODY:
Fiberglass/Carbon body panels are limited to hood, rear deck lid, fenders, doors, and bumpers. Cowl hoods may not be taller than half way point of the windshield. Forward facing scoops are prohibited on power adder combos unless factory installed or less than 5 inches from flat area of hood. Inlets for turbochargers and superchargers must not be exposed to ram air
INTERIOR:
Aftermarket steering columns are allowed. Factory type dash accepted. Must have carpet.
ELECTRICAL:
Optical devices are prohibited. All entries must have operational head lights and tail lights.
ENGINE:
Aftermarket blocks and cylinder heads are allowed. All entries must utilize a single carburetor cast intake manifold. Motor plates and solid mounts are allowed. Engine must be in stock location. Mufflers are required on all vehicles (except turbocharged combos). All SB power adder engines are limited to 440 cubic inches. SB N/A up to 480 cubic inch permitted with added 7 lbs. per cubic inch over 470 and BB N/A limited to 632 and BOP/BB Mopar power adder limited to 588. Any engine in question will be measured with a P&G gauge. A correction factor of 1.5% will be used. Competitors may be asked to remove a cylinder head for bore and stroke measurements should any discrepancies arise.
INDUCTION:
Small blocks and BB N/A combinations may use a single cast intake manifold with single carb or EFI. Small Block N/A may use cast tunnel ram/sheetmetal/dual carbs w/weight penalty (See*below)
POWER ADDERS:
Nitrous limited to SB and BOP/Mopar BB entries - Progressive nitrous controllers are allowed. Entries must utilize a single stage nitrous plate with one nitrous, one fuel and one redundant purge solenoid. Cross bar or perimeter style plate not permitted on BB Mopar entry. BB Mopar permitted single stage, single bar plate. Foggers must be disconnected and all solenoids must be capped off. Nitrous plates using fogger nozzles are not allowed.
Turbocharged (mid frame turbo only) and supercharged entries are limited to stock valve angle SB combos only. (SB CHEVY 23 DEGREE - SB FORD 20 DEGREE – 18 DEGREE MOPAR - FACTORY HEADED SMALL BLOCK FORD MOD MOTOR - LS CHEVY 15 DEGREE)
** NOTE: SB Chevy 23 degree Raised Runner – SB Ford 20 degree (SR20 –FT1 or T1RI or equivalent) not permitted with boosted combo
TRANSMISSION:
Any OEM style automatic or OEM manual transmission is allowed with power adder. Clutch assisted/clutchless manual transmission allowed on N/A. Manual transmissions must utilize SFI approved bell housing.
REAR SUSPENSION:
Stock type rear suspension or ladder bar only. Coil over shocks are allowed. Anti-roll allowed. Aftermarket replacement control arms are allowed. Stock frame rails must be in factory location, notching permitted. Corvette permitted any type of transverse leaf spring rear suspension. Wheelie bars are prohibited on all cars.
FRONT SUSPENSION:
Factory type front suspension only. Coil over shocks are allowed. Aftermarket replacement control arms are allowed. Aftermarket K-Members/Sub-Frames allowed.
WHEELS/TIRES:
A maximum of a 28 x 10.5 non W slick (N/A small block only), 28 x 12.50 ET Street or any 275 radial may be used on N/A, power adders limited to a P275/60-15 Mickey Thompson Tire P/N 3754R radial tire. Wheel width is limited to 12"
NITROUS WEIGHTS:
Base weight includes BOP combos – 3200
Mopar BB conventional B1 head - 3300
All heads 14.9 and under - 3250
Any canted valve head - 3250
All heads 15 degrees and above carry no additional weight
Any non-raised runner 23 degree combo – 3000
Any raised runner 23 degree combo - 3150
Blue Thunder Cylinder Heads - 3300
Any 20 degree ford – 3000
Any 20 degree high port SR20 –FT1 or T1RI or equivalent - 3150
TFS-R ford - 3100
SUPERCHARGER WEIGHTS:
F1A-3200
F1C – 3250
YSI – 3250
TURBO WEIGHTS:
T-76 - 3150
T-80 - 3200
N/A WEIGHTS:
N/A Inline head – 2650
N/A Non-Inline head – 2750
N/A (big block with standard deck height and conventional head) 2950 lbs
N/A (big block with tall deck height and conventional head) 3000 lbs
N/A (big block with standard height and big chief head) 3050 lbs
N/A (big block with tall deck height and big chief head) 3100 lbs over 589 add 100lbs
GENERAL:
No Billet cylinder heads/blocks
No Billet wheels on turbo combo
No Reducers on turbo or supercharged combo
Alcohol/E85 legal (meth injection legal on non-intercooled combo only)
All turbochargers (mid frame only) and superchargers must be as manufactured from factory
No muffler required on turbo entry, required on all other combos
No bull horns - front exit exhaust permitted but must not effect timing equipment
Gear driven supercharger allowed
Belt driven supercharger deduct 50 lbs
Boosted LS 15* add 50 lbs
Non Intercooled boosted combos deduct 50 lbs (no deduct if on Alcohol for fuel)
Leaf springs deduct 100lbs
*Cast Tunnel Ram/Sheetmetal/Dual Carbs on SB N/A add 50 lbs
Single 4150 carb/throttle body deduct 50lbs (N/A or NOS only)
N/A may deduct 100 lbs if using M/T 3754R tire
V6 entries deduct 200lb
N/A entries get a weight break and get to use a better tire.
Old 01-27-2013, 01:14 PM
Thanks,
Congrats to John he is flying for sure, but after reading those rules he better live it up wile he can. I think he will find him self about .2 slow within about 6 months. Maybe .3
I think this class will blow the F up
John Marcella
[email protected]
ph. 248-259-6696
Old 01-27-2013, 02:03 PM
R 70 Judge's Avatar
Yeah I messed it up.
BODY:
INTERIOR:
ELECTRICAL:
ENGINE:
INDUCTION:
POWER ADDERS:
TRANSMISSION:
REAR SUSPENSION:
FRONT SUSPENSION:
WHEELS/TIRES:
NITROUS WEIGHTS:
TFS-R ford - 3100
F1A-3200
F1C – 3250
YSI – 3250
TURBO WEIGHTS:
T-76 - 3150
T-80 - 3200
N/A WEIGHTS:
GENERAL:
Accepted Products
Accepted products deadline for Ultra Street/X275 Motorsports: Requests from manufacturers to have new products considered for addition to the 2013 season should be submitted before December 1, 2012 for the 2013 season. After this date, Ultra Street/X275 Motorsports will consider manufacturer requests for new products for the 2014 season.
Found these on yellow bullet.
James
1970 Trans Am
Old 01-27-2013, 03:59 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Thanks,
no, john sears says he will keep it in check.. LMFAO.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
