#621
Old 01-30-2013, 10:58 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
[QUOTE=Marty Palbykin;4843608]
Just curious to see if anyone else has had this done to their block and what the results were or if there are any other mods which should be considered while the engine is apart.
My question would be why !!!!
If you have good pressure this has never be a problem in my experience.
This may be a good procedure but I do not think it is really necessary under 1600 hp.
Marty P.
1600HP was the pump-gas goal.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #622
Old 01-30-2013, 11:32 PM
67'7F6'Bird's Avatar
67'7F6'Bird 67'7F6'Bird is online now
Who performed the machine work on your block and did your main bearing look anything like this?
This engine has only had a few NA dyno pulls.
Lynn McHackey probably supplied Used Bearings he had lying around.
Lynn McCarty and BES, What a Disgrace, this engine build has more issues/problems/mistakes than I have ever seen.
The word "Thief" comes to mind when you think you are working with Reputable People/Companies and this is the End Result. Not only was Ed's Money Stolen, think of all the time lost, stress involved and now try to Salvage and rebuild this Brand New Engine.
GREAT JOB LYNN!!!!!
Glad there are other RAV Heads coming out by a Different Supplier.
  #623
Old 01-30-2013, 11:43 PM
73 TRANSAM 73 TRANSAM is offline
What brand is the crankshaft? It seems like nobody check the clearance or maybe the bearing crush is minimal and the elongated cut in the saddle were leaking out in the side. But either way it seems like you are rebuilding your brand new proffesionally built engine. Like I said you are a better person than most of us. Goodluck at least you caught all these issues before making some power on this engine.
  #624
Old 01-31-2013, 12:58 AM
RAIV-Z's Avatar
The crankshaft is a Crower Billet.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #625
Old 01-31-2013, 08:07 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Did you modify the main bearings in any other way besides adding another oil hole?
just made the hole bigger, there was no groove on the bearing.
[email protected]. 3460#s
  #626
Old 01-31-2013, 10:38 AM
gene simmons gene simmons is offline
GREAT JOB LYNN!!!!!
x2
It gets more painful with every new photo that is posted.
Ed,i think you have the right people on it now. What happened to the rest of your signature?
Thanks for posting Marty,its good to have your input.
  #627
Old 01-31-2013, 10:54 AM
Rob B's Avatar
Rob B Rob B is offline
The longer this thread goes, the more it makes me sick and the more curious I am to see how its resolved. I hope you get this thing finally straightened out. As mentioned before, I commend you for not going "postal" on someone over this build, your a better man than I! I don't even want to think the financial investment you have in the build to this point.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #628
Old 01-31-2013, 08:12 PM
Jim Yanoski's Avatar
Jim Yanoski Jim Yanoski is offline
Quote by Rob B
"The longer this thread goes, the more it makes me sick and the more curious I am to see how its resolved."
Ed received a coupon for 10% off Vasoline from Lynn = RESOLVED IN Lynn's mind by the way it looks!
D-ports ROCK !!
  #629
Old 01-31-2013, 09:48 PM
Ed, I see no benefit in doing the mod on the crank bearing saddles that you posted.
The crank and bearings get lots of oil (from the normal oil hole in the bearing) in that
area of the crank travel/bearing shell geometry See attached picture (pdf).
The mod you show would add oil in the 12:00 to 2:00 area of the crank/oil feed diagram. No reason to add more oil as there is already plenty of oil there. What I believe has happened is that you have reduced the bearing shell support by a massive amount.
Tom Vaught
  #630
Old 01-31-2013, 09:51 PM
RAIV-Z's Avatar
Default Crower Billet Crank
Looks like the crank will need some cleaning up.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #631
Old 01-31-2013, 09:56 PM
mysticmissle's Avatar
Unbelievable.
  #632
Old 01-31-2013, 10:02 PM
RAIV-Z's Avatar
Tom Vaught
Great....Any idea why the oil groove in the bearing would have had work done to it?
Converted your attachment to jpg format.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #633
Old 01-31-2013, 10:17 PM
Marty Palbykin Marty Palbykin is offline
[QUOTE=RAIV-Z;4844283]Looks like the crank will need some cleaning up.
OMG SIR run do not walk away.
Marty P
  #634
Old 01-31-2013, 10:37 PM
cgeise's Avatar
cgeise cgeise is offline
When I saw this I wondered -- would all that area behind the bearing shell -- at 60 to 80 psi of oil pressure cause enough push to load the bearing on the crank ????
  #635
Old 01-31-2013, 10:41 PM
R 70 Judge's Avatar
Extra oil storage mod
Hope everything works out for you. The build sounded like it was going to be amazing but has quickly turned to chit
James
1970 Trans Am
  #636
Old 01-31-2013, 10:52 PM
Ed and I had that same conversation tonight.
Tom Vaught
  #637
Old 01-31-2013, 10:54 PM
We are talking major Elephant "Pies" here boys!
Tom Vaught
  #638
Old 02-01-2013, 01:15 AM
Looks like the grinder got away from someone when doing the chamfer on the oil holes.... damn!
  #639
Old 02-01-2013, 03:27 AM
I read through this whole thread start to finish in one sitting, about 2-3 weeks ago.
Just been keeping tabs since ... (too overwhelmed to make a post)
Since it keeps getting worse - no point in waiting for it to get better before posting.
Ed, back somewhere in the middle of this thread, you made mention of having requested the initial block to have the larger cam bores. But it didn't materialize.
Maybe that is coming into scope now.
Were you billed for the modification to the main journal saddles on this block (oil grooves) ? Or does it show on the "build sheet" ?
Was it ever discussed or advised ?
I ask because, maybe this mod was pre-existing.
Could be the reason this block was "chosen" was due to it being clearance sale priced.
[but undisclosed to your purchasing agent] - (as in someone was unloading this block - and he bought it unaware)
Pure Speculation - but with the issues presented all the way through re-inspection - nothing is off limits at this point. jmho
On the header issue - maybe the best thing would be to slightly modify / clearance a section of the valve cover(s).
The hack work on the heads is undescribable.
Just the fact they were drilled wrong from the start is bad enough craftmanship.
Not discovering it until AFTER all the porting machining flowing was complete - turned into EPIC Fail and carnage.
The maiden voyage of Ram V Aluminum heads could have been a Landmark Launching with this build.
Instead its more like the Titanic.
Helluva mess here Lynn.
Don't see how 500+ emails really caused all these mistakes or releases liability for them ?
  #640
Old 02-01-2013, 05:03 AM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
unfreakinreal
