| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Even if your car is stored inside, condensation can still cause rust on metal parts, and corrosion on electrical contacts.
The rust proffing done at the factory was minimal, and there is a lot of unpainted areas. The Packard 56 connectors are open, unlike the modern stuff. What I do is use a product called DampRid. It comes in tubs and bags with hangers. Available at Lowes, Home Depot, and most grocery stores. I place 4/5 tubs under the car, and hand one bag in the trunk and one in the interior. You would be amazed at how much condensation is captured bt the DampRid. A lot cheaper than fixing rust. |
Sealing your slab could help the moisture level in the garage significantly. Tons of water comes out of a slab for many years. If you can seal & keep the temperature constant (insulation) inside and use a dehumidifier you might stop the majority of it. Conditioning the space is ultimately the only way to be rid of it completely. With big temp swings outside and higher humid. levels, it is a tall order in an unconditioned space though.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 |
