Old 02-01-2013, 09:54 PM
Ron H's Avatar
Ron H Ron H is offline
Originally Posted by 67'7F6'Bird View Post
I've seen the headers first hand when they arrived and they "Do Not Fit" with the Valve covers prescribed and supplied for the build. You can't even get a side bolted on completely to the heads or get more than a few bolts/studs to fit at one time on each side. Also, the tubes are crooked, minimal effort was applied in the tube to tube welding with bad angles were each section meets the next, steps created at junction points, overall Very Poor Quality welding. Basically they SUCK.
Earlier it was stated that the headers were built with a different supplied set of valve covers than the ones he decided to use?
68 Firebird
Are you running with the wind or breaking it?
Old 02-01-2013, 10:03 PM
67'7F6'Bird's Avatar
Stock Pontiac Height valve covers were never the intended use. I guess, if you want maybe two bolts on each side to hold them on then they would work.
