Old 02-03-2013, 07:16 PM
mbwicz1 mbwicz1 is offline
Default Nitto Tire Size
I saw last month that Nitto has added a size to their NT450 line ('entry level high performance') which would fit some cars here...
275/50R17 27.8" diameter, 11.0 wide
255/50R17 27.1" diameter, 10.1 wide
225/50R17 25.9" diameter, 9.0 wide
It may not be the best of the best tires out there, but the 275/9" rear and 225/8" front would scratch my itch pretty well..... I'm not sure that I would want to run a 255/50 in front.
Mike
No Pontiacs in the garage right now.....
Old 02-03-2013, 09:45 PM
robscar's Avatar
robscar robscar is offline
The 1le brake swap is very nice, cheap, and pretty easy to do. I did it about 6 years ago. Big car spindles from Scarebird as he puts a taper in the ball joint holes so you can run stock joints.
Old 02-08-2013, 12:03 PM
67rstbkt 67rstbkt is offline
Do you have any links on the swap? Been searching around and have not found much yet. Thanks
Old 02-09-2013, 08:47 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Mike
275/50R17 has been available from Nitto for many years. I have run them on the rear of my truck for at least 11 years. I run 255/50-17 on the front.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
