Old 03-27-2013, 02:22 PM
Gator67's Avatar
Gator67 Gator67 is offline
Default WIW 70 Formula
Original and complete minus engine & transmission. Free of rust and dents, but in need of full resto after sitting in AZ sun. Carousel red, parchment?, 4-speed, non a/c.
Old 03-27-2013, 03:00 PM
2manyT/A'S's Avatar
Probably anywhere between $500 & 5000........Depends on how bad you want it/ what it really needs & what you intend to make it into...
You could easily drop 20-30K restoring it.....likely cheaper to find a decent original or one that's already done.
Eye Candy......garage band?
Go full screen & turn it UP!
Old 03-27-2013, 05:37 PM
That is pretty much the condition I found mine in and I paid $2800 for it in 2008. If you want to see what it will cost to do the car, you can view my thread since I posted the cost somewhere near the end.
http://forums.maxperformanceinc.com/...d.php?t=605832
Old 03-27-2013, 07:55 PM
The Boss's Avatar
The Boss The Boss is offline
What's the build date on it? Does it have the 12 bolt in it? Posi? Gears?
I might be interested in it if you want to flip it.
And go racin' in the street.
Old 03-27-2013, 08:10 PM
Gator67's Avatar
IIRC, 02B. Was told the original "10 bolt" is in it. I thought they all had 12 bolt in 70.
Old 03-27-2013, 09:19 PM
2manyT/A'S's Avatar
Did you check the VIN? (maybe it's just an Esprit with a hood)
Norwood build SHOULD have W66 on Cowl Tag.
ALL 1970 Formula 400's came with 12 bolts......
Old 03-28-2013, 07:01 PM
Gator67's Avatar
I've looked through your thread, thank you for including the link. General condition of the car I'm referring to seems a little better, but not significantly so...hard to tell from photos. Your car certainly turned out terrific...I'd be thrilled with that outcome.
BTWL: VIN and trim tag indicate Formula, Van Nuys, standard sandalwood interior, carousel red (U & L)
Car has decor trim group and all is there except wheel moldings and rocker trim. Also 14 inch rally 2s, rally steering wheel, rally gauges, console...will order my own PHS
Old 03-28-2013, 10:02 PM
Told you that 70 Bird bug was gonna get you, Jeff...
Sounds like a cool car!
Old 03-29-2013, 11:04 AM
Gator67's Avatar
You were correct, Keith.
Since correct engine, transmission, rear end are all MIA, am thinking 1 of none RA4 type of build...using a cleverly disguised IA II aluminum block & e-heads, 5-speed...otherwise stock appearing inside and out. I drive my cars, and this would be fun.
Old 03-29-2013, 12:03 PM
The Boss's Avatar
That's what I was thinking but with a real WW coded block in there, M-20 & 3:73 12 bolt. Really need to have an April-June build date on the cowl to be convincing - that's when the IV TA's were built.
Old 03-29-2013, 09:21 PM
It's on my "future project list" to build something like that, too. It's a long list, though, so not sure I'll ever get there
The car you found sounds like a perfect candidate.
Old 04-04-2013, 12:55 AM
Gator67's Avatar
Most likely I'll have to edit my signature tomorrow.
I intend to follow through with the basic plan I described below. Won't start until after my TA is finished though...maybe 3-4 months.
Name:	70 formula.jpg
Old 04-04-2013, 07:00 AM
The Boss's Avatar
Is that paint code 65 or 75? Looks like Cardinal Red in the picture.
Nice score - keep us posted!
Old 04-04-2013, 08:57 AM
Gator67's Avatar
Thanks. It's code 65...you can see Carousel Red under the hood, on the fender lips, door jambs, interior, etc.
Old 04-04-2013, 09:28 AM
The Boss's Avatar
Excellent! Nice grab!
Old 04-04-2013, 07:33 PM
Gator67's Avatar
...and so the fun begins!
Name:	dash 70 formula.jpg
ID:	318608   Click image for larger version
Old 04-04-2013, 09:24 PM
bird72's Avatar
bird72 bird72 is offline
That is a great find and a perfect set up and color. No AC, Gauges, Formula wheel, 4 speed, that is all business. The Judge color is over the top. This is one not matching numbers is less of a big deal because the car is just so cool regardless. Nice!
72 Bird
Old 04-04-2013, 09:47 PM
X2. Great find, Jeff!
Old 04-05-2013, 01:28 PM
Gator67's Avatar
Thanks, can’t wait to get started on this one. I should have it in my garage next week. I'll be able to disassemble (and document) at a leisurely pace because the body shop won't be ready for it until my TA is done--2-3 months hopefully.
Interesting tid bit…Jim Mattison called me after I sent in the PHS order and asked if the car is really two-tone consisting of, get this, a Palomino Copper lower and Carousel Red upper. Given what the trim tag says and all the Carousel Red that’s visible on the lower body, he chalked it up to a mistake on the factory invoice. Thank goodness...how ugly would that color combination be?
Old 04-05-2013, 10:16 PM
Jeff, was it an M20 or M21 car?
