I really don't know except the pulley for a Tempest does not look like the one for a Pontiac or other GM FS car. That is mainly what I would go by on a used pump. I try and keep track of which parts came off of which cars or by the pulley.
The flow control (pressure valve) is a part that you can remove easily from one pump and put it into another if need be. No need to take the cover off or apart.
Peter Serio Owner, Precision Pontiac Last edited by Peter Serio; 03-30-2013 at 06:09 PM. Reason: Added some more info. |
I needed a pulley for my PS pump on my 62 since mine was stripped at the keyway slot. I found one in Norwalk from an early 60's Pontiac FS that looked identical to mine. Same shaft diameter as well. The problem was alignment. I had to remove some material from the rear of the pulley so it would side closer to the pump to get it to line up with the generator pulley.
I had the car out today and saw my pump is leaking not the contol valve. |
