Old 05-05-2013, 04:17 PM
Gator67's Avatar
Gator67 Gator67 is offline
The car is coming together, but progress has slowed due to things we need to sort out.
As an example, here is a photo of the kickdown switch that was on the car previously. It's incorrect, very difficult to depress, and the bracket was modified to make it fit. Thought this would be easy to fix, but I haven't had any luck finding the right switch. Anyone have one for sale?
ID:	322202   Click image for larger version
Old 06-20-2013, 01:51 PM
Gator67's Avatar
The car came home last night. It was the first time my wife has seen the car since the front clip was removed, so she was really happy to see it all put together. She took it for a short drive and came back with a huge grin. Given how much I spent on the motor, she was afraid the car would be more of a hot rod, but it sounds and runs just like a factory stock car...just better...and that's what she wanted.
With total timing at 32 degrees, there's no sign of pinging using pump gas (91 octane), which is a relief. The vacuum advance is set-up and the vacuum retard is defeated as per the dealer technical bulletin. Cruising in stop and go traffic with A/C on and 100 degrees outside, the car ran between 190 and 200 degrees.
The change in gearing and tires is very obvious. Acceleration from a dead stop is a bit lazier with the 3.08s, but cruising is much more pleasurable.
We're going to give the car a good shakedown this weekend, and then it will go back to the shop next week for a couple days for final tweaks.
Name:	done almost.jpg
Old 11-04-2013, 01:07 PM
Gator67's Avatar
Hagerty Insurance photographed my wife and her car for some print ads/promotional materials. We started out early before the sun came up, but it was an absolutely beautiful morning and we ended up having a lot of fun! Here's a shot I snapped from iPhone.
Name:	Marcie Bird Hagerty Shoot.jpg
Old 11-04-2013, 01:46 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
that is really cool!
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
