Old 05-23-2013, 07:59 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Default 67/8 quarter ornaments ??
I have a bunch of the quarter ornaments but they need re-chroming. Are the current repops ok or should I look into re-chroming a set ??
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 05-23-2013, 08:31 AM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
There are good repops and there are bad repops. Here's a thread on that topic:
http://forums.maxperformanceinc.com/...d.php?t=669245
Edit: I found the pictures I took but not the article I wrote. Here's the most compelling reasons NOT to buy the cheap ones.
The studs are the wrong spacing and the shape is different:
This pic shows the difference in thickness, finish and stud length between the two:
The good ones are from Trimparts
68 GTO ragtop
91 T/A
69 XKE
