#1521
Old 05-27-2013, 07:09 AM
Judge273's Avatar
Judge273 Judge273 is offline
If you check it out get a copy of PHS too, and build date. Love to see if all those options are correct, and if the OEM stuff is in place.
Mike/Illinois
  #1522
Old 05-27-2013, 07:35 AM
74 SD455 Formula 74 SD455 Formula is offline
A non A/C car with 308 gears !!!!!! Is this right having a safety track posi in it ? I like the car....
  #1523
Old 05-27-2013, 08:13 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
i'd love the see PHS posted. that and more photos i think would only help sell the car..... not sure about the 3.08's,..seems like it should be 3.42's?...but it does look to otherwise be an *honest car* fwiw....
  #1524
Old 05-27-2013, 08:35 AM
Brewster's Avatar
Brewster Brewster is offline
Love the combo and wish it was close by to view myself.
  #1525
Old 05-27-2013, 08:54 AM
Held for Ransom's Avatar
So, the '71 had the dual straps for the alternator bracket? I don't think so.
  #1526
Old 05-27-2013, 10:43 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
Not hammering on it...but that's right, wrong alternator brackets. It just makes you wonder what else. I don't understand the 3.08 rear on a 4 speed car. Maybe it was 3.42 and he wanted a little better crusing RPM on the freeway.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #1527
Old 05-27-2013, 12:09 PM
2manyT/A'S's Avatar
If you read the auction description,I think seller states that PS was "dealer added" which would explain the "bojangle" alternator brackets......
Don't see ALOT of early 70's birds with manual steering,but as I recall,the alternator sits lower down where the p/s pump would go....
Seller also sates that the gears were changed out.....pretty sure a non-A/C stick would have come with 3:42's.....
Quoting the sellers description..... The original owner had the dealer install power steering, the Ram Air Option, and a 3:08 rear axle ratio (Safe-T-Track). This car was factory equipped with non-power front disc brakes.
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
  #1528
Old 05-27-2013, 12:21 PM
I'm not buying it. If a dealer installed the PS (which I did read), they would have used the correct parts due to the head accessory mounting holes change.
  #1529
Old 05-27-2013, 12:32 PM
2manyT/A'S's Avatar
If it's not on the invoice,it really doesn't matter WHO put it on as it's technically "incorrect" anyways...
Could have been a 1st-gen or A-body accessory P/S kit the dealer had in stock...
If you ever drove one of these cars WITHout P/S you'll understand WHY it's there...
  #1530
Old 05-27-2013, 02:11 PM
It's the wrong year for you Mike !!!!!!
Not a 74 HA-HA.....
  #1531
Old 05-27-2013, 02:21 PM
Not a 74 HA-HA.....
Also doesn't have the better SD engine.
  #1532
Old 05-27-2013, 02:42 PM
2manyT/A'S's Avatar
You must mean the SLOWER engine in the HEAVIER car......
  #1533
Old 05-27-2013, 03:37 PM
GREGGDOG GREGGDOG is offline
I am about a half-hour away from the 71 455 HO formula.
After asking to look at the car, the seller responded with, "I am not showing the car in person at this stage of the sale...thanks for inquiring."
  #1534
Old 05-27-2013, 03:56 PM
SD73's Avatar
SD73 SD73 is offline
Nothing suspicious sounding about that....
  #1535
Old 05-27-2013, 04:19 PM
Judge273's Avatar
Wow, I never even got a response to my request for the PHS....
Mike/Illinois
  #1536
Old 05-27-2013, 04:51 PM
njsteve's Avatar
njsteve njsteve is offline
I hope he knows that no show = no bid.
  #1537
Old 05-27-2013, 04:56 PM
True. Strange.
Perhaps he was saying the bidding is only open to morons at this "stage of the sale."
  #1538
Old 05-27-2013, 05:35 PM
When manual strg was ordered for '71, 72, 73, one could not get the Formula wheel. The pics claerly show a Formula wheel, guess it was "dealer installed" too? The alt straps are '69-early '70 (exc '70 Bird). The P/S parts shown on the car are definitely earlier than '71 style, the style of pump mtg pieces also require the use of earlier style pulleys. Chrome valve covers are also earlier. The seller notes "In 2003 I began an amateur restoration of the car with the intent to make it a nice "driver." The car was not built as any type of show car." Having bought a LOT of original '68 & later manual steering pieces over the last two decades, with some even purchased off original owners who had their '68-71 Pontiacs "upgraded" at the dealer to factory power steering, I just can't see the cobble job not in the early 70's at a Pontiac dealer, reminds me more of the results of amateur wrenching with few parts resources.
As far as the gearing goes, if the 3.08's were actually installed early on at the dealer, that is extremely odd. Would love to see pictures of the inscribed dates on the gears & it would be nice to see pics of the dealer paperwork to support "dealer installed" comments for the gears. The original '71 Formula & T/A rears I've torn down & rebuilt had the Warner-Motive cone type posi's. This cone type posi does not hold up well. Maybe the reason for the rearend build in the 90's, again be nice to see pics with the differential cover off.
  #1539
Old 05-30-2013, 02:12 AM
beltrunner beltrunner is offline
Default My Formula 455 HO on Ebay
For all you guys hammering on my car...I can only state the information that was given to me along the way, and since I'm only the 3rd owner of the car, and I knew the 2nd owner for all the years he owned the car, that story line is not real long. When my buddy (#2) bought the car in 1986, the car looked like new. He entered the car in a show at a National POCI Convention in Las Vegas in the late 1980's. At the show, John Sawruck awarded the car his "Favorite Car" trophy, and talked to my buddy at length about the car,stating that he always preferred the Formula over the Trans Am. John Sawruck didn't knock the car because the power steering was not year-correct, or the Formula steering wheel was probably "cobbled" together by some moron amateur, or the rear end gears could not possibly have come with the car, or whatever else you nit pickers are criticizing the car about. He awarded the car a First Place Trophy for being his "Favorite Car." And as far as the axle goes, it is stamped "GYG", and yet #1 stated that he had this ratio installed at the dealer when the car was new, along with the power steering,Ram Air, and probably the chrome valve covers...go figure... I don't know all the whys or wherefores on this stuff, but can only tell what I was told. As far as me "Cobbling" the car together like an amateur short on parts, I didn't change a thing on the car when I took it over. I only replaced worn out stuff and tried to make the car look nice, but still practical as a "driver,"not something I had to keep in a bubble locked up someplace where nobody would ever mess with it. And for "ol Pinion head out there...I've been working on cars for almost 60 years now, and know a thing or two...you might know a lot more than me, I dunno, and I respect your knowledge and experience...but your attitude SUCKS...I joined this sight as a friend amongst friends for some advice and help in building my car, and I really did get some valuable information along the way...this negative feedback kind of takes the fun out of it. And just to pass some friendly information on to anyone selling their car. I only went to this ebay thing because I nearly got ripped off the first two times I tried to sell my car the old fashioned way, by word of mouth and taking it to local car runs. The first rip-off attempt involved a stolen cashiers check...and the second failed sale involved a whole stack of counterfeit $100 bills...only my ties to law enforcement enabled me to keep my car...I hope none of you ever has this grief...so good luck to you all, and be careful out there...
  #1540
Old 05-30-2013, 02:52 AM
2manyT/A'S's Avatar
Welcome BACK to the forums......
WE DO pick at cars here...that's kinda our thing...and there's very little NOT to like about your HO Formula......it's a 40+ year old car that gets DRIVEN and wasn't built to win judged car shows.
It's unfortunate that you didn't connect with Greggdog because I'm sure he would have posted a positive report on your car for us...(and you)
GOOD LUCK with your car auction/sale & thanks for warning about the SCAMS.......
