Replacing the passenger side header gasket on my 1978 TA with Hooker Headers, purchased the vehicle with the headers installed. Removed all bolts with no issues. Having extreme difficulty getting the rear center port bolt started. Any tips or tricks to get this bolt started. The remaining 5 bolts are easy. Appreciate any info. Thanks
Get them all started 1st. before running any bolts in , bring them all in even .
cut the center divider and the pipes will be easier to get started and seal better. My time in between gasket changes has been great as well. going on 6 years now and only have a slight tic.
http://i558.photobucket.com/albums/s...9c1e9df3.jpg?4 |
You want to start that bolt first, or at least only slightly start the other bolts, before you install that one.
If you have any of the other bolts drawing the header up, it will be difficult, or impossible, to start that bolt as the top of the bolt will hit the header tube and won't let you get the bolt verticle to the threads in the hole. Loosening/removing the collector can sometimes let you get the header in a better position. They make header bolts with 3/8" heads that provide a little more clearance. it can help to dent the tube a little bit where the bolt inserts. You can use a long socket extension and then hit is with a hammer from the side. I have cut down some wrenches and heated/bent some to use for this project. If you have the header off the car you can slot that bolt hole. Then you can push the header forward to get clearance to get the bolt started and then pull it back to the rear when you get it close to tight. |
All of the above, a lot of patience and some cursing usually works for me on my 76TA.
If you separate the header tubes, you may have to re-tighten once it heats up, most likely several times / heat cycles. I've found you are better off only separating the rear tube from #8 and #7, there's less warpage/alignmnet issues that way. (the front bolts aren't an issue most of the time anyway) There are some headers where #1 & #2 suffer the same issue as #5 & # 6 bolts, so it's best to work those 2 bolts on both sides first, at the same time. ( #1 rear + #5 rear, and #2 rear + #6 rear). .
I have the Hookers and just went though this last year. Same bolt, #4. Disconnect the collectors and make sure there is no pressure from the rest of the exhaust system. Put #4 on first. It will take a little fiddling, but stick with it and it will go.
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
Using an alignment bar for bolt holes is in the list, and it's typical method of bolt alignmetn for header installs.
Agree with others to seperate the gasket into 3 pieces, and start all bolts loosely. I slot the bottom of the gasket bolt holes and hang the gaskets on the loose bolts.
Am I missing something here? All the Hooker's Ive had use a "key hole" slot for the bolt hole you mention...The idea is you start it (with gasket) prior to hanging header and slip header over it and then slide it to pick up other holes..Believe this applies to both D-port and RAIV ports but not a 100% sure. Just hung a set of Super Comps...
I do know the D-ports are a Biotch......but then they all are...IMO..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Your going to have to pull all the bolts back out and start that bolt 1st with gasket then hang the header slide it back and then install other bolts. Collector will need to be disconnected so you can slide the header onto the keyhole
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
I don't mean to hijack this thread but my last experience was just awful. I will be re-installing headers on a different set of heads on my 79 T/A and wondered if I could just use red silicone sealant instead of gaskets. We don't use gaskets on our aluminum headed stock car, just red silicone and never had a leak. Has anyone done it on gen 2 firebirds?
Thanks for taking the time to reply. All are great suggestions. I think Joel and 60 Man have the right idea with utilizing the Key hole Slot on the Hooker's. I knew it had to be there for a reason. What a great Forum. I will button this thing up tonight.
go for some header studs or ARP's 5/16" head header bolts
they are a life saver on D port headers and make it so much easier |
