Old 06-16-2013, 08:39 PM
462ta's Avatar
462ta 462ta is offline
Default exhaust backfire causes 72 firebird 400
started getting exhaust backfire's recently, very loud pops. does it on intial start up when cold and does not do it once engine is warmed up.Changed normal gas station last 2 tanks. running quadrajet. could it be vac leak, what else can i look for before i blow my mufflers apart thks.
1972 Formula ram air, 406, 60916 cam, forged pistons,rods. stock 69 intake, 13 heads home ported, quadrajet, tri y headers, 3 in exhaust, 3.23 gears, auto, CE frame connectors 275/60/15 back 255/60/15 front.
Old 06-16-2013, 08:59 PM
Stuckinda60s Stuckinda60s is offline
Intermittent pop in the exhaust usually means a failing condenser, assuming you don't have HEI. If you do have an HEI, it could be a module problem.
The problem is an indication of an electrical problem where it loses fire momentarily.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 06-16-2013, 09:09 PM
462ta's Avatar
running pertronix in original dist
Old 06-16-2013, 09:49 PM
66bonne's Avatar
66bonne 66bonne is offline
Too rich at idle or mild flooding at start-up [?]. Leading to excess fuel getting in exhaust and igniting. How do the plugs look ?
Jim
Old 06-17-2013, 07:27 AM
The exh system on a cold motor that was just started up does not have enough heat to light off extra un-burned fuel!
I would pull the Q-jet apart and I bet you will find that the primary power piston it somewhat hung up and not providing enough enrichment, or you have a vacumm leak some where.
Is the motor hard to re-start when fully hot, as in cranking slow?
Old 06-17-2013, 01:32 PM
chiphead's Avatar
chiphead chiphead is offline
Do you have to pat the gas a lot to get it to start cold? If you fill the exhaust with unburned vapor and then throw an exhaust flame into that, it'll bang pretty good. Also verify base timing hasn't slipped and become retarded.
Old 06-18-2013, 08:39 AM
462ta's Avatar
car starts just fine when hot and cold needs a few pumps of the gas but same as its always been, have not had a lot of time to track things down but so far i found the dist advance bushing had fell out-using piece rubber hose-but that should not be the problem and of course i pull my timing light out and it does not work so i need to pick up another one to verify timing.
Old 06-19-2013, 12:42 PM
462ta's Avatar
went and got a new timing light hooked it up and guess what #1 cyl is firing intermittently, put new plug in and looks good now, hope this was my problem
Old 06-20-2013, 07:20 AM
That should do it unless it was a bad cap or plug wire .
