#1001
I also would be interested in seeing what the Buick shroud looks like. I saw one for a Corvette, but question where their electrical connector plugs in compared to the firebird, and whether it would interfere without some modifications.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#1002
The sad thing is I have been through a dozen rebuilders (NAPA, too) and even brand new Delco units and they all eventually seep oil from that front seal. This covered the gamut from regular passenger vehicles, trucks and the recent Pontiacs. This particular one held a perfect vacuum for an hour with no leakdown whatsoever pror to filling it with the proper amount of R12. We did the proper oil seal run in by hand turning the compressor clutch for a couple minutes to lap it in. I even pulled the vacuum down, and then it held the vacuum for 2 months while I did other work to the car prior to the refilling day. A buddy of mine was a GM line mechanic for 20 years back in the 60s and 70s and is still a great mechanic. He is the one that worked on this car's system. He laughed when I asked him to place a bet as to when the oil would start leaving the telltale line under the hood. He said that in all his years of working on A6 equipped cars, he never found an original compressor or even a replacement seal that would not eventually leak oil from the front hub. Some of it has to do with the rebuilders that soak that piece of felt/sponge that is in the center of the hub. The sponge is supposed to hold the oil in place and keep it from wicking out onto the clutch, but most rebuilders oil the sponge first, so it gets oversaturated and just throws oil out forever. Hopefully this car has the oiled up sponge situation and not an actual leak. It stills blows really cold. I just get irritated because I really notice the oil droplets on a flat black underside of the fiberglass hood. I will check out NAPA and see what they have. The problem is my buddy doesn't have an R12 recycling machine anymore so I'd be wasting the R12 fill in order to swap out to another (probably leaky) compressor. I will say that maybe it has to do with the higher pressures that R12 makes in the original system. My Gramma's 75 Esprit runs an A6 but is filled with Freeze12 which was a replacement refrigerant. With this refrigerant you only used 2/3 of the factory fill spec, so it is not running at the factory high pressure. That car has an almost nonexistant oil throw off and has held the charge for 5 years now. 70RAIII, I really do appreciate your technical input. You have helped me out a bunch over the years with brake and alternator parts/repairs. You don't happen to have a "pre-run in" compressor sitting around do you? :-) Last edited by njsteve; 06-16-2013 at 08:22 PM. |
#1003
'nother one.....?
http://www.ebay.com/itm/1968-77-Olds...5fbd02&vxp=mtr Sounds like this one is a "knock off" of the Olds version... As I recall,the Buick one is quite different.....more like the "chinese" camero one.. If 2 different GM divisions made a shield,there MUST have been leakage issues....from day one...
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
#1004
Do you have a part number for the NAPA $79 compressor. Their website prices start at $249.
#1006
Steve, I didn't get a chance to say hello at PY this weekend, but wanted to say congrats on the hard work your car looks great.
71 Starlight Black Formula 455 L75 88 Flame Red Metallic GTA Notchback |
#1007
I found a couple for $199.00 on the website..Look up 1973 Chev Truck or 1980 Buick Wagon.. These off the path vehicles will be cheaper. Plus, NAPA has 2-3 different options for compressors. One is a standard 2 year warranty, the 6 month warranty is enough and is the cheaper unit..If NAPA cannot find one using their computer, ask for their compressor book. Then look up compressors by picture. You will find a page or two of A6's at various prices- you will have to rattle off part numbers while they look up prices.....A6's seem to go bad almost immediately if they are going to..Also, even if you spend a couple hundred, you will get a non leaking unit that will be better.. Did you use the correct viscosity of oil? Plus did you clean out the dryer and muffler??They need to be both newly cleaned inside with new dissectant installed..
#1008
Muffler cleaned put and a brand new receiver dryer, and filled with correct modern oil for use in R12 units, after draining unknown amount of prexisting oil in compressor. System works fine (and has for a month or so since being filled). It just leaves the oil film under the hood. When it was filled, the pressures were well within midrange of the spec and nowhere near the max. If I recall correctly, he filled it to the point where the bubbles in the sight glass just disappeared, which was less than the actual fill spec. I was behind the wheel at the time checking the outlet temps.
As an added bonus, the oil was dispersing on the exact same plane as the power steering pulley groove on the crank pulley...so you guessed it - extra squeeling from the power steering belt. Its definitely the ps belt as I removed all the belts to isolate the squeel and that was the only belt that made the noise. |
#1009
I tightened the PS belt and it stopped squeeling. :-)
The A/C is still working fine and blowing at 37 degrees. I'll live with the oil spatter till it stops cooling so well. My 72 T/A did the same seal oiling thing for several years and the cooling was never affected. |
#1011
Today's question involves the factory trim clips for the body side moldings. These are the moldings with the rubber insert that run along the middle of the fender, door and quarter to deflect other cars' doors.
I was lucky enough to pick up an NOS fender piece off ebay and it actually had the factory clips in the package! Now I need to find some duplicates for the rest of the car since someone, along the way replaced them with push in plastic clips that don't hold the trim securely enough against the body. Does anyone have an idea of where I can get some more of the correct clips? Here's some close ups of the NOS factory clip: ![]() ![]() ![]() ![]() The shiny gold clip is close but not close enough to work properly. When mounted into the back of the trim piece, you can see that because the retaining wire is not mounted in the same spot, it moves the stud off of center where it needs to be to mount correctly on the car: ![]()
#1012
#1013
#1014
Good example of why this forum is so popular!
BJ
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership |
#1015
My daughter recently asked for lessons on how to drive a manual transmission. Today was the day for the "road test."
It was a rather hysterical time. It was as if Mel Brooks directed the whole thing. Everywhere we went some strange animal would pop out. It included two completely unrelated flocks of turkeys with a dozen chicks, deer that climbed up trees, groundhogs, flying squirrels, blind joggers, and a dead skunk. She actually did very well, only stalled a couple times, and remembered to press in the clutch when she got to a stop, most of the time. Now it's time to go take the car apart and replace the clutch, again. Here's a shot of one of the turkey flocks impeding her travel and forcing a down shift. |
#1016
I spoke to the guys at Restoration Specialties and they commented that I had the clips installed wrong. The attached wire is supposed to be bent back upon itself to serve as a retaining spring. Once you do that, the shiny replacement clip does in fact work properly. I bought 30 of them and the accompanying nuts.
#1017
Those clips.....or ones so close I can't tell the difference.....are also used on some 70's Fords for retaining body trim strips.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
#1018
They had a bazillion different clips at Restoration Specialties. I was glad I sent them the photos and the guy then rattled off the exact part number off the top of his head. He said that he had a couple of the original green ones left but not nearly enough as I needed for the car.
#1019
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#1020
