Old 06-24-2013, 08:52 AM
LeighP's Avatar
LeighP LeighP is offline
Just a thought...don't forget to wire some sort of safety switch arrangement t osupply the power to the pump.
Holley make an oil pressure safety cutout switch, you can wire a momentary ON contact switch to bypass the safety switch for priming the carbs prior to starting.
Another idea - I use an LPG Gas system safety switch on my car...has a tach pulse input...no tach pulse, no power to the fuel pump. The big advantage on this idea is the switch has a few seconds of power to the pump when you first turn the ignition on...enough to prime the carb.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
