#741
Old 07-04-2013, 11:19 PM
Wish you the best, Ed. The new stuff looks nice. Thanks for the offer on the motor home deal at Norwalk, wish I could take advantage of the offer. Maybe another year my friend.
Tom Vaught
  #742
Old 07-05-2013, 09:07 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
What, if anything did you do to solve the lifter tie bar/to block issue? I don't think our Crower lifters were nearly that close to the lifter bore tops. Make sure you have the correct Pontiac lifter bodies and that the bodies ARE NOT CROSS DRILLED. They are supposed to be cross drilled and then plugged on the side where the block feed is. If the cross drilling is left open, you will have way too much oil to the top end. Best of luck with your engine.
The lifters are Crower 66260-16 Full Body Mechanical Roller Lifters (.842" dia. / .750" Bearing).
I do have a vague note about "Modify Lifter Oiling". I'll take a look later today and see if they are cross-drilled and also measure the clearance between the lifter bars and IA-II block at various lifts.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #743
Old 07-05-2013, 12:40 PM
cgeise's Avatar
cgeise cgeise is offline
We had to machine the lifter boss's a bit at the tie bar area for clearance. in the old days -- now I run raised seat lifters and allllll better
  #744
Old 07-05-2013, 02:09 PM
RAIV-Z's Avatar
Curt, can you supply a part number?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #745
Old 07-05-2013, 02:18 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
I have the same lifters as you, but when I started my motor the first time I wasn't getting any oil up top. I removed the restrictors in the block and still had the same issue. There is a thread about it somewhere on here. I ground a very small grove from the oil hole to the oil band on the lifter. Then the oil seemed fine but I still bought .030" restrictors for my new pushrods.
My tie bars are very close as well, but after having it on the dyno and running in my garage they made no contact. I pulled them out for inspection last year and they looked good.
Good to see its moving forward. Hopefully I'll see you at Norwalk.
Jeff
  #746
Old 07-05-2013, 02:33 PM
Good Info!
Tom Vaught
  #747
Old 07-05-2013, 02:41 PM
cgeise's Avatar
Call Crower - you want a raised seat lifter with pin oiler and offset if you need them - they now have the bushing style also -
  #748
Old 07-05-2013, 02:42 PM
cgeise's Avatar
Jeff
The contact will depend on the base circle of the cam -- bigger cam = small base sometimes - now you have contact -
  #749
Old 07-05-2013, 02:43 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
I believe you can get those Crowers from Bill Cerralli at Checkered Flag Machine as well.
  #750
Old 07-05-2013, 02:53 PM
cgeise's Avatar
Only if you dont want them this year!!!!!!!!!!
  #751
Old 07-05-2013, 03:04 PM
GTO Dan's Avatar
Yeow...it's getting hot in every thread today.
  #752
Old 07-05-2013, 03:07 PM
Is that a Crower issue and not necessarily a BC issue where he is stuck?
Tom Vaught
  #753
Old 07-05-2013, 03:30 PM
cgeise's Avatar
Crower has been great -
  #754
Old 07-05-2013, 03:34 PM
OK
Tom Vaught
  #755
Old 07-06-2013, 09:20 AM
RAIV-Z's Avatar
Default Crower Roller Lifters
Here are the mods which were done to my crower solid roller lifters. Looks like BES at least tried to resolve some of the lifter bars clearance issues.
ID:	328861   Click image for larger version
ID:	328862   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #756
Old 07-06-2013, 01:10 PM
You said you put a different profile camshaft in the engine after the BES work, so in this case, maybe you reduced the clearance somewhat based on your new camshafts base circle dimension.
Tom Vaught
ps Better to always ask the question when you see something that doesn't look right.
  #757
Old 07-06-2013, 03:50 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Ed,
What did the new machine shop do to the heads at the previously welded rocker stud holes?
Watching with great interest and looking forward to even greater news on the finished product...Best of luck.
  #758
Old 07-06-2013, 05:30 PM
RAIV-Z's Avatar
Tom Vaught
The cam has been changed, the rocker bar clearance does look tight on a #1 and #3 which are the only 2 which have been installed with the new cam. The block has some marks indicating clearance issues which I don’t believe happened while the new cam was being degreed using test springs.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #759
Old 07-06-2013, 05:47 PM
RAIV-Z's Avatar
Originally Posted by Jim Robertson View Post
Ed,
After they stopped chuckling, we started with a basic exorcism, when that didn’t work, we machined the rocker pads flat so I could have a T&D rocker shaft made and also performed the following:
1) Set it up for dry deck using aluminum plugs
2) Cut o-ring grooves “figure-8”
3) Tapped water x-over holes
4) Drilled and tapped missing water x-over hole in one head
5) Installed heli-coils in rocker stud location and only bottom row exhaust flange
6) Spot face exhaust flange top row bolt holes so I can install header bolts from the top
7) Resurface heads
8) Replaced the valve springs
9) Splashed holy water on the heads and wished me the best of luck
I’ll take a look at my notes to see if I missed anything.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #760
Old 07-06-2013, 05:52 PM
Ideal situation would have been to trim the lifter bosses before the whole assy went together. Would have to install cam bearings in the block and install the camshaft that would be used and measure the tie bar clearance at every position. Then if necessary put the .080" clearance milling in the block bosses. Not Rocket Science.
Tom Vaught
