If you took the engine from the crate and ran it you have a point.
But you took it a part to redo it. So now you need to inspect every part and that means every bolt hole. If something is missed now it falls on you the builder / assembler. Stan
The point was to inform other guys who might have purchased heads.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Your point about bolt holes drilled through or too deep is a good one. Very common on any aftermarket head or block. I have seen this on Tiger heads, IA 1 Blocks, early E heads and many brand X parts. I generally fix this with a short set screw and lots of pipe sealer with teflon on the threads. Put it in the hole first, then your regular fastener in next. Problem solved. Usually, after they make a run or two of the parts, these type of issues are solved in the machining program. Good luck on the dyno!.
