Old 07-24-2013, 02:54 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Was this done to increase PTV clearance because of the new cam's greater lift, or you wanted to increase squish clearance to reduce max squish velocity, or some other reason?
If I read the cam cards you also did the firing order switch.
Stan
0.080 was the recommended thickness to support double O-rings with a solid copper gasket.
Firing order was changed. The first cam was also supposed to have that as well, got a song and dance instead.
We'll be using the turbo headers connected to 3" pipes on the dyno.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 07-24-2013, 10:41 PM
Travis Q Travis Q is offline
Hope things go better for you this time around, Ed!
TQ
