Old 07-24-2013, 10:02 PM
dwid's Avatar
dwid dwid is offline
Default 69 GTO parts
I have a long list of 69 GTO parts available. I accept PayPal and I will ship to anywhere in the US or Canada. Please be patient as I don't get online everyday. I will try and get pictures posted if I can. I do have some larger items available at the bottom of the list but these will be local pick up only please. I am located about 2 hours from the Detroit or Buffalo border crossing. You can also email me direct at [email protected] or give me a call 519-461-9332 (before 10pm EST)
Fixed headlight mounting plates, buckets, trim rings and brackets - $100 pair
inner grills with trim (one side pitted) - $75
Headlight bezels - $85
Front bumper brackets (all 4) - $135
15/16" front sway bar (blasted and primed) - $40
Turn signals (complete with housings, bezels, lenses, fillers and brackets) - $125/pair
Passenger side front lower control arm - $35
Upper control arms $35 each or $50 pair (2 pairs available)
Rear lower control arms (modified boxed) - $60/pair
Rear upper control arms (modified boxed) - $40/pair
Rear coil springs - $50/pair
Saginaw power steering gear - $65
Pitman arm - $30
th400 speedo cable - $25
Transmission back lock brackets and guard - $20
69 GTO red dash (nice core, has tear in the top) $75
Heater box with heater core, outer cover, resistor and harness - $125
Heater controls (non ac car) with bezel - $50
Gauge pod cluster housing - $75
Gauges (with bezel and printed circuit) - $200
Kick panels (will require painting) - $75 pair
Hood hinges - $75 pair
Wiper transmission assembly and hardware - $65
throttle cable and plastic firewall mounting plate - $35
Headliner bows and clips - $40 set
Headliner tack strips with hardware - $50 set
ash tray assembly (paint to match, rusted inside) - $25
Auto shifter assembly - $75
e brake assembly with pedal - $45 complete
engine frame mounts for 400 - $50 set
glove box door and latch mechanism (paint to match) - $50
Under rear seat cable protector - $25
Trunk torsion rods - $35 set (2 available)
gas pedal assembly (complete) - $35
rear bumper support bumpers - $20/pr
Door hinges - $75/all 4
Door latches and lock mechanisms - $65/pair
Front lower valence panel (middle section rusted out but excellent for repairs) - $25
Front lighting harness - $50
Intermediate lighting harness - $50
Dome lamp with harness - $25
Dash harness with fuse box (everything there except plugs for steering column) - $125
Lower windshield stainless - $75
front windshield stainless - $50
fender stainless mouldings - $15
Rear window corner mouldings - $20/pair
Seat belts (several colours and locations no sets) - email with needs
Rear view mirror with all mounting hardware (red cover) - $25
Stainless window tracks - $50 pair
front armrests with pads (paint to match) - $50
Rear arm rests (green) with pads and ribbed ashtrays - $50
Sun visors and brackets (need to be recovered) - $30/pair
brake pedal and pedal pivot bracket - $35
rear bumper brackets (set of 3, rusted and need to be straightened) - $30
original rad support center bracket - $20
front drip rails - $20/set
Tail light housings (plastic) - $50/pair (have 2 to choose from)
rear marker lights - $25/set (will need new bezels)
headlight switch - $20
wiper switch - $20
Trunk latch assembly - $20
Gas tank straps - $25 pair
front ductwork - $25
dash ductwork - $20
Front disc brake set up - $275 (spindles,rotors,calipers,brackets.shields etc)
disc brake proportioning valve - $50
Front steering set up (tie rods, centerlink, idler arm) - $75
Center links - $30 each
Transmission tunnel metal (nice shape) - $40
red door panels (need to be redone) - $150 (complete)
red window laces - $75 for all 4
15" trim rings - $50/set
Rad support top plate, centre brace and brackets for 70 lemans $20
Steering column and pedal pivot bracket $25
mid 70's Pontiac dog dish hubcaps - $60/set
Listed below are larger items that I prefer not to ship:
rear glass (2 or 3 to choose from non tinted) - $100 each
front windshield (2 to choose from) - $125 each
Rear seat upper and lower (red, nice core) - $50
Full firewall and tunnel metal - $100
rear package tray with trunk lid hinges etc. - $85
Trunk divider panel with rear crossmember (where trunk divider meets trunk pan) - $85
Inner rear quarter structures with sail panel - $75 a side
Roof with sub frame - $100
Hardtop frame (needs work) - $350
Complete bucket seats (red) - $500
69 trunk lid (requires work) - $150
Inner fenders - $125/pair
Door glass - $65 each
Rear quarter glass - $65 each
Doors - $100/each (have a few to choose from)
Rear bumper (needs straightening and re chrome)- $65
Front fenders (need heel patches) - $125 each
Fiberglass rear quarters - $75 each
Old 07-24-2013, 11:59 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
I can use the fixed headlight parts listed. PM sent
Plus I can use some other parts
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 07-25-2013, 11:24 AM
Scott Thelander's Avatar
Default Hi
Are the 69 turn signals complete ?
with the rear retainer/bracket
and the fiberglass surrounds ?
pics to
[email protected]
thanks
Scott
Old 07-25-2013, 06:55 PM
dwid's Avatar
Default turn signals
Hey Scott,
signals are complete with lenses, bezels, housings, fillers and mounting brackets. Pics on the way. I will give you a call tonight.
Thanks,
Dan
Old 07-25-2013, 06:56 PM
dwid's Avatar
John
I will send you an email about the fixed headlight stuff or give me a call 519-461-9332
Thanks,
Dan
Old 07-26-2013, 12:37 AM
android 211 android 211 is offline
Is the dash harness for idiot lights or gauges and was it an a/c car?
Old 07-26-2013, 07:21 PM
dwid's Avatar
Default harness
The dash harness was for idiot lights and a non AC car.
Old 08-08-2013, 07:19 PM
dwid's Avatar
Default items sold
door glass, 15" trim rings, dash ductwork and vents - SOLD
Thanks Jeff
Old 08-10-2013, 09:33 AM
dwid's Avatar
Hood Hinges and front signal fillers are SOLD
Thanks Errol
Old 08-10-2013, 04:39 PM
dwid's Avatar
arm rests and rear lower control arms are SOLD.
Thanks Mike
Old 08-10-2013, 04:49 PM
Bob-o Bob-o is offline
Can I see some pics of the red dash core? How much would you estimate shipping to be to 48166 S.E. Michigan?
Old 08-10-2013, 08:34 PM
dwid's Avatar
Default dash pics
here are some pics of the dash.
I will get you a shipping quote tomorrow, just have to measure and get an approx. weight.
ID:	332805   Click image for larger version
Old 08-11-2013, 01:07 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Dwid-
Could you post a few pics of your tail light housings?
Thanks!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 08-11-2013, 07:58 PM
dwid's Avatar
Default tail light housings
here are the pics, they are a bit dusty
ID:	332926   Click image for larger version
Old 08-19-2013, 08:30 PM
dwid's Avatar
dash harness SOLD
Thanks Mike T
dash core, rear springs, heater box are SOLD pending payment
Old 08-25-2013, 10:41 AM
dwid's Avatar
Default items sold
Dash Core, heater box core and harness, wiper transmission and rear springs are SOLD.
Thanks John
Old 08-26-2013, 03:37 PM
blue goats's Avatar
blue goats blue goats is offline
Looking for nice front ds drip rail stainless steel
Thanks,
George
Old 08-26-2013, 07:48 PM
dwid's Avatar
Default drip rail stainless
Hey George
I do have extra drip rail moulding but the one your looking for has some dings on it and would need to be cleaned up.
Old 08-30-2013, 10:55 AM
blue goats's Avatar
I just need the A pillar piece . How is that part ? Or do you want to sell the whole set ( A, coupling and over side windows.)
Old 09-01-2013, 02:41 PM
dwid's Avatar
Hey Blue goats,
I have attached a pic of the driver side drip rail moulding. It has 4-5 small dings in it (you can see a couple in the picture). If your interested $15 plus shipping.
