I know this sounds to simple but I learned many years ago in high school with my first 389 the lifters will tap if the oil level is a little low.
Before you start this engine I would drain the oil and look for brass flecks I know it would have you better results to get it warm first also take off oil filter and cut it open look for metal . cheap insurance to change the oil and see then use a broomstick and damage the engine more not that the stick idea is bad. just running the engine at this point could cause more damage
I burnt a bearing not to long ago but I knew right off that it was a bearing, it was burnt not scored so I had no metal in the oil
Gentlemen put your trust in God, But mind to keep your Powder dry. Oliver Cromwell Michael Hughes Sr 1966 GTO Convertable: Stolen never recovered 1966 GTO Hard Top .30 over 455 4-Speed 3:23 Posi |
HF sells a cheap auto stethoscope works well I have used a long extension as metallic noise travels well up metal as Merlo suggested start puling plug wires in the area of noise if it changes then you have some lower end issues and shut down the eng drain oil and check if not pull valve cover see if you have a collapsed lifter exhaust noise is more of a tick than a knock loose flex plate or cracked flex plate will also cause a knock.
