Old 08-13-2013, 07:06 PM
Poncho 400's Avatar
Poncho 400 Poncho 400 is offline
I've used lowes peel and seal aluminum as a heat barrier and lowes reflectic insulation as a sound deadener on my corvette and bird . works great and a lot cheaper
Old 08-14-2013, 10:45 AM
David Jones's Avatar
Ditto.
I did mine about 4-5 years ago. Quieter. Cooler. No weird smell. Stays put.
Old 08-27-2013, 06:09 PM
gbowlin68 gbowlin68 is offline
Originally Posted by David Jones View Post
Ditto.
So you used aluminum roll roofing over a good asphalt based primer?
Old 08-31-2013, 04:05 PM
cfd2bc's Avatar
cfd2bc cfd2bc is offline
I have used Dynamat for most of my projects in the past. I thought I'd give the the home store stuff a try. I used the Frost King aluminum duct insulation and it worked great. No wierd smells and easy to use. I used my dyamat roller to roll it on. The dynamat is a little heavier and probably insulates a little better, but I did the whole car for like 37.00! Perfect for what I was looking for.
