#41
Old 09-05-2013, 11:52 AM
OVERULD's Avatar
OVERULD OVERULD is offline
Sweet car Steve - Congrats!
BJ
  #42
Old 09-05-2013, 12:18 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Wow! What a neat car! And you didn't have to go international to get it! What's your plans? Leave as is or your detail touch to it? Still love the 73 Formula thread.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
  #43
Old 09-05-2013, 12:23 PM
I have never been in a faster, scarier, more original car...til now.
SD Power to the Front!
  #44
Old 09-05-2013, 02:13 PM
necdb3's Avatar
necdb3 necdb3 is offline
I would be pulling the rear seat bottom off looking for the build sheet
Dave
  #45
Old 09-05-2013, 02:16 PM
4birds's Avatar
4birds 4birds is offline
Thumbs up
Congrats on the purchase Steve. We are all jealous of you right now! You are a lucky, lucky guy to own a couple of the rarest of the rare Formulas. (you obviously worked, sacrificed and earned it) How soon do we get to see pictures of the Black and White together?
  #46
Old 09-05-2013, 03:00 PM
Grandma's wheel isn't correct for 73 .
The 74 car posted has had the center wood grain painted black. iirc
Can't recall seeing that combo - and can't remember what my 74 Bird had now.
The other wheel you pictured alone with full wood grain "might" be right.
In GTO's - 71 or 72 was last year for color keyed inner cushion.
Then they went to the wood grain like that on all 3 spokes.
Do all your home work before grabbing anything.
This is the restored Blue 73 SD Formula - not saying this is the full correct wheel - just laying it out there ....
Name:	73 blue sd formy1.jpg
  #47
Old 09-05-2013, 03:06 PM
The wheel on the Blue 73 looks like the same textured vinyl color-keyed wheel like found on 69-71 GTO and Bird .
just laying it out there as a reference only
  #48
Old 09-05-2013, 03:23 PM
The color keyed column with contrasting Formula wheel grabbed my attention the first time i looked at car on eBay . But had to double check myself before mentioning it .
i wouldn't leave it that way - either of the 2 options you have would look good .
Straining to remember - but really seems like my 74 Bird had the wood grain spokes.
Here is the 73SD Silver Formula with Saddle and Formula wheel .
Name:	73 silver sd formy2.jpg
  #49
Old 09-05-2013, 04:40 PM
gto4door's Avatar
gto4door gto4door is offline
Very nice car NJSteve. Congratulations! Car was ordered May 9th and picke up July 31st. Might want to try tracking down Mr. Enrico Stein to get more history on the car and why he ordered it that way.
gto4door
http://automotivehistorian.wordpress.com/
  #50
Old 09-05-2013, 04:43 PM
njsteve's Avatar
njsteve njsteve is offline
The prior owner tried to find him for many years. I think he may have passed, but I will resume the search. A lot of the SDs sat around in order status until Pontiac decided to actually begin production.
The Following User Says Thank You to njsteve For This Useful Post:
  #51
Old 09-05-2013, 05:00 PM
Held for Ransom's Avatar
Re: the hood.
Because it was a SD Formula, do you think it's possible the hood was prepped separate from the front end and added later during the build?
Steve, what's the date code on the hood?
  #52
RicksGTO's Avatar
RicksGTO RicksGTO is offline
There is a 78 year old Enrico Stein II with a former address in Port Washington, NY. Sent you the link in a PM with a phone number and possible relatives names.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #53
Old 09-05-2013, 05:34 PM
Larry Navarro's Avatar
Very cool car Steve!!
Even though we couldn't strike a deal on mine, you picked up a sweet car!
  #54
Old 09-05-2013, 06:16 PM
cnc's Avatar
cnc cnc is offline
Wow nice car Steve.....kinda looks a little like mine....
Name:	2013-08-01 19.19.42.jpg
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #55
Old 09-05-2013, 08:09 PM
njsteve's Avatar
Thanks Larry.
I think all I did when we were discussing your car, was convince you that you should not sell it to anyone! :-)
  #56
Old 09-05-2013, 09:29 PM
I'm sure this steering wheel must be from my '74 GTO.
My '74 blue interiored Formula has the same style and I remember the old red one having a black wheel looking the same.
  #57
Old 09-05-2013, 10:27 PM
njsteve's Avatar
Finally took the lady for a ride tonight. The gas tank was empty so I drove 5 miles to the gas station. Filled her up and just before the tank was full, gas started trickling out from the front of the tank. I drove her home quickly and put a floor jack under the rear end to raise the back up and stop the fuel leak. Turns out that one of the vapor return lines had popped out of the two inch rubber connector hose at the front of the tank. I replaced the rubber hose section and all is well. While I had the wheel off I took these shots
I also found the source of the exhaust rumble - the tailpipe is about 1/64" from the lower edge of the bottom of the quarter. I tried using some gentle persuasion to rock the entire system toward the driver's side. It is now 1/8" away.
The Following 2 Users Say Thank You to njsteve For This Useful Post:
  #58
Old 09-05-2013, 10:30 PM
njsteve's Avatar
And here are a few shots of the black car and the white car together:
I have no idea what the bright sparkly thing is under the front of the white car. There is nothing in the other photos in that spot. Scary car spirits?
  #59
Old 09-05-2013, 10:53 PM
blue71ta's Avatar
blue71ta blue71ta is offline
yes, and the '73s are the same. Exactly what I was trying to say earlier...thanks Mike.
  #60
Old 09-05-2013, 10:58 PM
njsteve's Avatar
So is the consensus that the center area in the horn pad should be black on a Firebird and not woodgrained (like on the A-body)?
Is that '74 wheel up for grabs or is it just a photo from your archives?
