Old 09-16-2013, 02:27 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Default Street legal drag tire
Looking for a new radial tire. My TA BFGs are old and hard (and getting smooth). Car is a 66 GTO 4 speed m21 w/GV OD, 12 bolt posi 4.10 gears Hop stop bars and adjustable arms. Tripower 428 w hyd roller XR288HR 450 hp est. I don't put a lot of miles on, but need more grip for the street to transfer weight. It transfers great w slicks at the strip, but have a race car so it don't go there much. Size 275 60 R15
Looking at BFG G force tread 1 or 2, MT, and others... Your thoughts???
Thanks for your time.
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 09-16-2013, 03:18 PM
Hooter's Avatar
Hooter Hooter is offline
True street legal, I'd go with the Mickey Thompsons. I've got a set of 255's on my '65 and it pulls the front wheels with them.
67 Bonneville ragtop
The Following User Says Thank You to Hooter For This Useful Post:
Old 09-16-2013, 03:28 PM
torqjunki's Avatar
torqjunki torqjunki is offline
X2 on the Mickey THompson drag radials. They ride very well, do ok in light rain if you get caught out with them. On a limited use vehicle they will last a good while especially if you don't spin or haze them. Last ones I just bought were a little different.....they had a few extra treads. Think they were called drag radial II or something.
Just noticed your in Midland. I live there from '98 to 2000. Do you know Mike Cooke? Whats he up to?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
The Following User Says Thank You to torqjunki For This Useful Post:
Old 09-16-2013, 04:10 PM
66bonne's Avatar
66bonne 66bonne is offline
Here is another vote for Mickey Thompson ET Street radials. They are a good looking street tire that performs very very well at the track. Running the 295/60/15s right now.
I tried the comparable M&H. They were fine on the street but marginal at the track.
Jim
The Following User Says Thank You to 66bonne For This Useful Post:
Old 09-16-2013, 04:18 PM
Nitto has a new tread design, they worked fine oin the stock '04 GTO. The older Nittos on my TA at San Antonio I could never hook. Mickey Ts hooked good until they got older.
Old 09-16-2013, 04:38 PM
Hooter's Avatar
Good point on getting older. My first set seemed to get hard and quit hooking after about 3 years.
Old 09-16-2013, 04:45 PM
1978 T/A's Avatar
1978 T/A 1978 T/A is offline
I would look at the new MT ET Street Radial Pro.
The New Nitto Tire NT05R is good. But they only offer it in 17" + sizes.
1969 Verdoro Green GTO
#Matching 400 + .045, 4.21 Ohio Forged Crank, SD 290 KRE heads, Torker II, OF Cam, Etc...
1978 W72 Marty Blue T/A GONE
The Following User Says Thank You to 1978 T/A For This Useful Post:
Old 09-16-2013, 05:59 PM
ponjohn's Avatar
ponjohn ponjohn is offline
It is a whole different story with a stick.
It may require trial and error.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 09-16-2013, 07:38 PM
JKrull66's Avatar
Thanks for the comments, I was leaning to the MT's... True the w/o the stick the TA's would probably work ok... a friend with a chevelle gets along good w/them. The stop hop bars/poor mans 4 link works great at the track but seems to be harder to hook on the street... Hope to hear more comments.
Thanks, Guys!!!
66 GTO HT Cruiser
POLARIS 900 RZR
Old 09-16-2013, 07:40 PM
JKrull66's Avatar
The street radial pro is for the street? will have to look up...
66 GTO HT Cruiser
POLARIS 900 RZR
Old 09-16-2013, 07:44 PM
JKrull66's Avatar
Yes I know Mike well, he has been working on a couple Mustang projects, and is fixing up the TA for his daughter to race. Great guy!!!
66 GTO HT Cruiser
POLARIS 900 RZR
Old 09-16-2013, 07:50 PM
66bonne's Avatar
I'd be a little leery of the 275 radial pro for the street. Not much tread pattern on them.
They sure do work well at the track.
Jim
Old 09-16-2013, 08:04 PM
goatless's Avatar
goatless goatless is offline
I was going to suggest a Goodyear Polyglas... but then I saw you wanted a radial.
The M/T is the way to go for a street legal radial.
But those old school Polyglas hook better than any regular street radial.
1966 GTO
The Following User Says Thank You to goatless For This Useful Post:
Old 09-16-2013, 08:29 PM
JKrull66's Avatar
Good to know...
66 GTO HT Cruiser
POLARIS 900 RZR
Old 09-16-2013, 08:44 PM
huddie huddie is offline
I have been using Mickey Thompson ET Street radials on my 62 Catalina for years and they work great for me except if I get caught in the rain I drive like an old lady,Ha Ha.
The Following User Says Thank You to huddie For This Useful Post:
Old 09-16-2013, 08:50 PM
goatless's Avatar
Good to know...
I know a few guys that have run them into the 10s with a 4 speed.
1966 GTO
Old 09-17-2013, 09:38 AM
V-Ped V-Ped is offline
If you plan for mostly street driving, I have found very good daily driver performance from the Nitto 55's. I think they offer darn good wet road performance for a drag radial as I have been in numerous gully-washers common in our west Texas climate. They do need help on the track but I use traction compound for a little extra help there when needed. I have tried the BFG's and I think the Nittos are better all around. I haven't tried the MT's but looking at the tread, I am concerned about wet weather performance. I have Nittos on two of my cars for every day driving but do keep a set of slicks on spare wheels for a just-in-case.
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
Old 09-17-2013, 09:54 AM
torqjunki's Avatar
Vped.....are you referring to the Nitto 555-r or the 555? I ran the 555 for a while before going to the MT drag radials. For sure the 555 is a good street tire for all weather situations, but not much straight line grip. The 555 r is the soft compound version and appears to still have lots of tread for rain and such. Been thinking of trying some of the 555-r.
Old 09-17-2013, 11:00 AM
issach428's Avatar
issach428 issach428 is offline
Has anyone tried the m&h drag radials? They have a few oddball sizes
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 09-17-2013, 01:23 PM
ta man ta man is offline
I've been caught in the rain a couple times with my Mickeys they work fine as long as you are easy on the throttle.
