Old 10-05-2013, 02:31 AM
Darth Menace Darth Menace is offline
Originally Posted by goatless View Post
All of the pieces you mention are commonly available.
and I would LOVE to know if you have some sort of write up on your car and what it takes to get the 69 to go 12.6 in the 1/4
Old 10-05-2013, 01:05 PM
goatless's Avatar
goatless goatless is offline
It was in HPP many years back with a little more mild combo-
http://www.highperformancepontiac.co..._4/benson.html
It ran a 13.1 the day after the shootout, which is the best it did with that setup.
Still running a very similar setup, but heads have mild porting, hydraulic roller cam, GM30 3000 stall converter and 3.73 gears currently- pretty much everything else is the same. Oh yeah, G7014 Goodyear Polyglas tires replaced the M/T Drag Radials.
Still totally streetable- I'll hop in and run a few hundred street miles at a time without touching a thing after being at the track.
1966 GTO
Old 10-05-2013, 02:42 PM
How in the world do i get the windowfelts off (front at the moment)? When the window is down you can get two out, but there are 3 or 4 more screws that you cant get access too. And with the window up there is no hope for getting to them
Old 10-05-2013, 03:34 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Unfortunately you will have to pull the window out.
Old 10-05-2013, 07:07 PM
goatless's Avatar
Actually, you don't need to pull the glass out, but you do need to loosen the stops inside the door to let the glass go down a little farther so you can get to the screws.
1966 GTO
Old 11-19-2013, 06:39 PM
hey doing a windowfelt order. Does anyone know if the windowfelt on a 69 gto the same as windowfelts on a 69 tempest? I seriously have no idea of the differences of these cars
