| National Events Events that normally draw audiences from more than a 10 state range |
One more note. For Popular Vote, the GTOAA will decide the classes based on registrations so voting is by class.
You've seen the description of my GTO from the previous posts, so what class would I be in? Is there a list of classes somewhere?
1968 GTO / 400 HO / 4-SPEED |
Pat68HO,
The classes are dynamic. The GTOAA will make them up based on registrations (they could combine some years or break a certain year into multiple classes for example). The only decision you need to make when you register is if your car is "stock" or "modified". I must refer you to the GTOAA for class information. See http://www.gtoaa.org/pdf/popvotechart.pdf When you arrive, you will go through a tech inspection to determine if your car is stock or modified. Please take the time to determine if you think it is one or the other before your register. It will save a lot of time in tech if the class is correct (68 stock or 68 modified). |
| The Following User Says Thank You to MLouttit68GTO For This Useful Post: | ||
Pat68HO,
As Mike said concours would be out for you only spending one day. You would do Popular Vote. If you came Thursday and went through tech inspection you would be classed as stock. Depending on how many 68 & 69 hardtops we get whether you would be grouped with just 68's or with 68's & 69's. If you came early Friday morning and didn't go through tech inspection you would go in the 2 Late 2 Class class which would include any GTO from 1964 to 2006. Hope to see you next year. |
