Old 11-02-2013, 04:18 PM
njsteve's Avatar
njsteve njsteve is offline
I did a bit of cleaning today. I covered the front end and the engine compartment with a giant plastic sheet and then cleaned the underside of the hood where 40 years of the A/C compressor had been spraying oil. I guess after all those years of emulsifying, the A/C oil residue actually dissolved some of the original overspray from the underside of the hood. I also pulled out the washer fluid and antifreeze overflow reservoirs and soaked them in hot water and detergent. They cleaned up nicely. Both of them had gunky residue layered at the bottom.
I then went for a ride to my buddy's garage and checked and see if the A/C worked. I wanted him to be looking at the sight glass when I turned the A/C on to make sure there was actually R12 in there. (I didn't want to just turn it on, just in case it was empty, and possibly burn up the overheat switch).
Miraculously he said that it was only slightly low on the fill. Looks like it has been holding pressure for all these years!
The Following 2 Users Say Thank You to njsteve For This Useful Post:
Old 11-02-2013, 04:35 PM
njsteve's Avatar
I also adjusted the rear brakes. I had noticed that the pedal, while firm wouldn't do anything until halfway down and then the front discs would grab very hard. I carefully removed the original Tinnerman star clips that hold the rear drums in place and pulled the drums. It was all untouched and original in there. The brakes really needed to be adjusted. It took two full turns of the adjusters to get the shoes out to where they would actually contact the drums. I then reinstalled the drums and the Tinnerman clips and went for a test run. It worked like a charm. Now it stops like a normal car.
When I got back from the test drive I pulled the Radial T/As and installed the set of 40-year-old, Firestone Steel Radial 500s (three NOS tires and one of the original tires from the car). She looks a lot different with the GR70x15 Firestones versus the 255/60x15 T/As.
The Following User Says Thank You to njsteve For This Useful Post:
Old 11-02-2013, 04:45 PM
RamAir's Avatar
RamAir RamAir is offline
Man, that looks perfect Steve! Looks like she's ready for the MCACN class of '73 display!
Old 11-02-2013, 08:25 PM
njsteve's Avatar
Thanks!
Oh, and by the way, now that the kickdown switch is connected, boy does that make a difference!
Old 11-02-2013, 11:51 PM
70RAlll 70RAlll is offline
Steve.. there is word that applies to your car- patina.. I think you are doing your level best to remove any and all patina that survivor car has remaining. Cleaning/soaking the overflow/washer fluid reservoirs, the underside of the hood etc. that is beautiful messy original patina that can never be reproduced - why would anyone remove that from a ultra rare survivor like you have here?? .. . just my opinion here Steve ..but you may want to step back and slow up on over cleaning that car.. then again, you have removed a bunch of the survivor patina already-that originality is gone, never to return... in my opinion.. you are doing more damage than good by over cleaning this car. There may have been 10 70-73 low mileage untouched survivors left, one less with your car now..
I know I am not alone in my opinions on survivor cars.. still lost why you would overclean this car.. for the 73 SD Formulas, must be one of a couple that were still original with its well earned patina..
oh.. I have a set of TA mud flaps if you need them.would help protect your car from rock chips real well.lol..
Old 11-03-2013, 09:51 AM
njsteve's Avatar
Bill, I respect your opinion but we tend to disagree on what constitutes patina: “a surface appearance of something grown beautiful especially with age or use”. I consider it to be the original finish of the car that has been weathered with the advance of time but not the sum total of the contaminants that accumulated upon it, over that period of time.
When a hoard of gold treasure is brought up from a sunken ship, the salvagers spend years removing the concretions to get to the actual coin and then stop at that point to preserve its patina. They don’t keep the coral on the coins. More importantly, they also don’t go buffing out the coin once the coral is removed. They reach the point of the original finish and stop. That is what I have done – no repainting, no touching up of flaws or chips.
The process of what I have been doing is following the Hippocratic Oath of “Above All, Do No Harm”.
The master cylinder rebuild was done because the internal contamination was so bad it actually destroyed the insides of the unit and dissolved the piston. It was leaking fluid down the inner fender and onto the frame rail. That had to be addressed. The black fluid inside was progressively destroying the remainder of the system. I kept the original remnants of the factory paint on the master cylinder body. As for the rear drums, I spent an hour carefully unscrewing those little copper clips that hold the drums on to the studs. I replaced them at the exact spots they were, originally. I adjusted the adjusters so the brakes functioned. Yes it was interesting that the assembly line never adjusted the brakes to contact the drums, but their inattention, while noted, had to be addressed to prevent the car from being destroyed in an accident.
The original carburetor was reinstalled after replacing two main gaskets and a modern accelerator pump. No alteration to the finish – not a drop of carb cleaner touched that carb. The replacement carb that was on there was put on in the 1990s and I wanted to return the original patina’d unit to its throne.
The coolant overflow and the washer bottle were both filled with this rusty, goopy, silt at the bottom that was not good for the continued operation of the car. Their overall color/finish did not change – just the garbage inside was removed. The radiator had 40-year-old antifreeze that had turned bad and had to be replaced before anything more was damaged internally. The heater core was replaced and the original clamps were reinstalled in their exact positions. The later, rerouted bypass hose was removed (it had a 1987 date code on the auto parts store, heater hose). The original thermostat was sticking and corroding from the old coolant, and had to be replaced. Any removed parts have been retained, of course.
The engine and transmission still have all their oil and grease covering underneath. I have tightened the valve covers to stop the leaks but didn’t replace any gaskets. The distributor cap that was on there was a dime store, generic replacement and an NOS original was found to replace it. And the NOS cap was from 1973-4. The compressor oil leak pattern on the underside of the hood was gently cleaned away because it was an overall accumulation, most of it in recent years. (Remember, you said these A-6 compressors didn’t leak oil when they were new!). The original oil filter was saved and will be reinstalled for shows. I have been letting it drain for the past month or two. That was 30-35 year old oil in there and it was black and contaminated with fuel.
The kickdown switch had to be connected for the transmission to work properly. And once again, like the unadjusted rear brakes, the assembly line inattention, while anecdotally significant, had to be addressed to prevent transmission damage.
The hood release cable grommet had to replaced since the cable was sawing its way through the brace with every activation of the hood release, and could have snapped the cable at any moment. The saw mark groove is still there but the cable now rides in its correct grommet.
The original steering wheel was returned to its original position. You have to admit it was some kind of Divine intervention that lead to its return after 40 years...in the desert (Arizona, not Egypt).
The poly valance replacement was the only "alteration" I have done to the car, finish-wise, but that was to return the look of the car to the way the original owner, Rick bought it. He had the dealer replace the broken valance at his cost, when the car was new. He was informed that the warranty didn't cover "body work".
BTW, Rick fully approves of everything I have done to his car. That’s why he keeps rewarding me with more parts and artifacts as the process moves along. :-)
I did keep a sample of every foul-smelling, corroded fluid I removed from the car, and I will gladly trade them to you for those mudflaps! ;-)
Old 11-03-2013, 10:14 AM
transam1972 transam1972 is offline
Default patina
NJSTEVE I think your car looks better now, clean away!..really why would someone not clean there car?..lets take the fun out of owning a Firebird
Old 11-03-2013, 10:27 AM
njsteve's Avatar
Thanks. I do enjoy a good debate, though, once in a while.
It kind of reminds me of the scene in Princess Bride between the Sicilian and Dread Pirate Roberts and their battle of wits. :-)
Old 11-03-2013, 10:46 AM
RamAir's Avatar
I'm with you on this Steve, you are doing what's necessary to preserve the integrity of the car. Keep cleaning away, but it looks like you have it covered.
Old 11-03-2013, 01:09 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
It is still a right here in America to have an opinion. It is also an old saying that " opinions are like noses, everyone has one."
As far as removing the " patina" of a low mileage survivor car, opinions definitely run strong! Just where does one draw the line?
If, for example, my survivor car has a leak from the timing cover front oil seal that leaves a puddle of oil on the garage floor as well as contributing to the " patina" of the oil covered pan, trans and floorboards, do I repair it? After all, that leak helped to create the oil " patina" that covers the underside of my car. Also, if that seal should be replaced, should I clean off the dirt and oil covered components and preserve any bare metal that will soon rust OR leave those components dirt and oil caked and then re-establish a matching dirt/ oil " patina" on any and all securing screws or bolts?
Here is another question: my car has a quarter size rust hole at the bottom of the passenger fender, obviously from the drain hole that had become plugged over the last 40 years. So, my 14,000 mile survivor car has an ongoing deteriorating condition that will continue to get worse as time goes by. Should I have it repaired to preserve the original date coded fender that Pontiac installed in 73 or just let it rust away for the sake of the " patina'?
Steve's car has a remarkable history and it is apparent that he is preserving the originality of his car.
Oh, that's right; it IS his car after all!
