must have power windows and power locks...its all wrapped in the same harness...but they are actuated by a door jamb switch...theres 2 door jamb switches with seat locks
can do anything ya want to put the effort into
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
The electric seat back release is a 1970 option and up, never available on a 1969 nor correct as they had vacuum powered locks in 69 and 70 went to the superior electric locks.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. |
you can do it easily without the door lock option, you need to use a 12v relay that's switched on with a ground signal rather than a 12v signal and just splice the ground wire into the regular door jamb switches. Original harnessing on the seat release option used separate switches that connect 12v to the solenoids when activated where door jamb switches ground for turning the dome lights on. Now, here's the roadblock: 69-72 bucket seats look the same other than the covers from the outside, BUT the seat frames are actually different between 69 and the 70-72...you won't be able to mount the seat release assemblies into a 69 bucket seat.
I found that out the hard way after wasting my time attempting to install this awesomely handy option on my 69 after doing the same to my 71! Obviously they redesigned the seat back frame for that release on the 70 and up seats. |
