Ok, how cool is this? Pontiac honeycombs in the back of the Green Truck headed for the tire guy. So I hauled the honeycombs to the guy and got them broken down this morning. Off the books - $20 tip with no waiting. Thanks to Greg's tip below, the project is moving along quickly.
Greg - thanks for the great suggestion. ![]() ![]() ![]() ![]()
| The Following User Says Thank You to Bentwheelbob For This Useful Post: | ||
The dates should be around the interior of the rim not on the face. They are stamped in rather large fonts with a two letter code, where it was made and a date I think? I think you can actually see a portion of one of them on the rim in the lower left of this photo. Looks like a 12?
Here's a photo of what I mean:
| The Following User Says Thank You to njsteve For This Useful Post: | ||
OK, it must be a sign of the apocalypse when two of the PY masters give differing information. Well, maybe not.....
Here's a couple of examples of what I have. How do you interpret the stampings? ![]() ![]() ![]() ![]() ![]()
I know what the MADE IN USA and the 15x7 mean. :-)
But as for the other codes, I will defer to an expert for those. (BTW, Aren't you going to remove the stick on weights?) |
HFR - thanks. Sounds like a bunch of orphans. |
The stick ons were used because they allowed for a more accurate balance. Because of the heaviness and uneven loading of that urethane face, these wheels are very hard to balance to our pickiness level. And I also wanted to keep the weights off the face side of the wheel for aesthetic reasons.
I checked the outer codes on the honeycombs that came with the 72 when I bought it and they are an orphan later set, as well. As I recall i went through a dozen wheels before I found a nice balance-able set that I used for the radials that are on your car now. The next best set were used for the bias ply set that went with the T/A and the really wobbly ones were used for trunk mounted spare tires. Last edited by njsteve; 11-10-2013 at 11:10 AM. |
