Old 11-26-2013, 12:18 AM
Default Under the hood.
Its leaking almost everything from everywhere. It doesnt run that great either I;m not sure what to do about it. Budget may be tight and there may not be enough cash for a rebuild. Its just ugly.
I was told water pump is new last summer but it doesn't look like it. Fresh Anti freeze sits on top of it.
ID this carb?
PS pump looks original and both hoses are frail.
Old 11-26-2013, 12:27 AM
A couple more before I put the car away Saturday.
Old 11-26-2013, 12:59 AM
GT182's Avatar
GT182 GT182 is offline
IIRC you said it's not the original engine. I see a 2bbl, is that a 326 in it? Just wondering. Leaks can be fixed if nothing is broken or cracked.
That grant steering wheel should have a darker finish on it. It should match the walnut veneer on the dash, then it wouldn't look so bad. Once you get used to it it has a better feel than the original sw. I've got the same sw in my GTO and it like it better than the skinny original. But that's me.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-26-2013, 09:34 AM
It is a two barrel. Carter. The motor casting checks out at 9773155 date code E224 (May 22 1964). So it is a 389, but someone through a little carb on it at one time.
Old 11-26-2013, 09:47 AM
1966geeto 1966geeto is offline
Enjoy the car and fix it while you drive it it's 47 years old we all have a few leaks at 47 .Are the headlight bezels orig mine have a dimpled center section so am wondering if mine are correct to bad you so far away would love to help you straighten out the kinks.
Old 11-26-2013, 12:26 PM
GT182's Avatar
Glad to hear it's 389 Paul. For some reason it didn't look right.... probably because of the 2bbl and the intake. Sorry I made you nervous but I had to ask.
Has to be a 389 out of a full size Pontiac... Charles and I say so too. BTW... my dad's 64 Star Chief had a 389 with a 2bbl Carter.
Gary
Old 11-26-2013, 12:51 PM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
Looks good Paul. It's a balmy 34* in Chicago today. Perfect weather for cruising around with the top down.
Bill Nawrot (Wino Bill)
1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019
Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot
HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/
YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU
1967 GTO Conv
Old 11-26-2013, 01:36 PM
Thanks Bill. I saw your car this weekend at MCACN. Looked great.
Old 11-26-2013, 01:35 PM
Gary
Just curious as to why? The stamp on the distributed pad on the block is GTO and the heads are GTO. What makes you feel it's from a different car?
It appears that when someone put the GTO 389 in the car, for whatever reason they put an intake and carb from another Pontiac on it.
