'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed '66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed My Garage Tarheel Tigers Pontiac Club of Raleigh, NC |
Just curious as to why? The stamp on the distributed pad on the block is GTO and the heads are GTO. What makes you feel it's from a different car? It appears that when someone put the GTO 389 in the car, for whatever reason they put an intake and carb from another Pontiac on it. Last edited by Old Blue 66; 11-26-2013 at 02:11 PM. |
Thanks Bill. I saw your car this weekend at MCACN. Looked great.
Congrats on the very nice 66 GTO convertible.
I believe the carter AFB is a 4 bbl. I think i see 4 squirters. Unless my eyes are playing tricks again.
Scott If you always do what you always did ![]() You always get what you always got
Sure looks like the intake on my '63 - 389, with the heater hose (minus the valve) entering the front instead of at the rear of the block. But the water pump looks like the later model 7 bolt, where my '63 is a 4 bolt. I think the housing is a little different also. All this is by memory which has started failing me lately
You guys are confusing me... I don't see a 2bbl carb anywhere. I do see a Carter AFB, and pretty much everything else that looks like my '64 GTO's upper end. I however did not research the block casting to determine if it is '64 vintage.
If I remember correctly, '63 389 does not have the holes for a block mounted starter, and using one of those engines in a later model has additional challenges. |
I see a Carter AFB 4bbl in the pics. Not a 2bbl. You could wrap the original wheel with a leather cover and 'run it' as is. Better than the Grant, and low $$. I would replace the PUI seat covers with Legendary or something that has real pleats. The flat looking PUI covers really stand out in an otherwise very nice looking, solid GTO ragtop. Congrats....you have a nice one to work with.
Jeff |
Paint the drums red Paul. '66 got red drums behind the Rally 1 wheels. The rusty drums distract from the nice wheels.
It's obvious at a glance that it's a '64 and earlier intake, and from what b-man posted about the casting number, it's a '64 GTO block also. It is a 4bbl Carter, which would be correct for the engine.... So, what's the problem? Sounds like a pretty rare and desirable engine to me, even though not as desirable on your car as it would be on a '64...I say RUN it man.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 11-26-2013 at 02:31 PM. |
As another observation, and I can't see too well because of the picture, I'm not so sure about the lower mount of the alternator. Something seems amiss. I'm kind of wondering if it might be out of alignment, and that is why they could not install the second alternator strap. It appears to be a '66 PS setup, as the '64 has a cast iron mounting bracket.
Belt misalignment would contribute to the dirty nature of the engine compartment due to black belt dust covering everything. As a note- my friend Rick ran 13.50's with his '66 Lemans convertible using a 64 389 motor I traded him that had 132,000 miles on it. No mods to the motor at all. |
Im gonna make the call based on what Ive been able to figure out on the stampings that it is a 64 GTO 389 with matching heads. And based on what everyone is saying here - a 4bbl. That thing just looks small. 1964 389 325 HP 79 J A 10.75 009 9770716 1-4 3649S GTO Option Block Casting # 9773155 Last edited by Old Blue 66; 11-26-2013 at 05:10 PM. |
It is hard to tell where coolant is leaking from up there. Anywhere related to the water crossover & its connections to the heads & the front cover often leak. Also the front cover to the block can leak. It does look like there is a new unpainted water pump & of course that could be leaking too. Sometimes you need to clean things up & catch it in the act to find the source or sources. Very nice car! I too like the color. My first '66 was a martinique bronze LeMans with a black vinyl top. The color looks great in a subtle sort of way.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald |
If your carpet is just faded you could spray it with dye to bring the color back.
It was replaced at one time and cut poorly. It needs to go.
Another way, if you have a Stant pressure tester, is to use that. It's basically a small hand pump that screws onto the radiator cap fitting. You latch it on and pump it up to ~30lbs or so. Any leaks will show up. You can get one for 50 bucks or so on ebay or maybe borrow one from the local Auto Zone for free. They have lots of tools to lend out.
Greg Reid Palmetto, Georgia |
#38
Nice car Paul, congrats! Does the heater work? It was COLD on Saturday
![]() I agree with everyone that all the things you mention are minor fixes. I personally think its fun to decode all this kind of stuff and do some work on the old cars. |
#40
Based on the few clues I have to work with, I'm going to guess the replacement of the water pump was done haphazardly and not torqued to spec, failing to seal properly resulting in coolant weeping by the gasket over time. You can check the bolts but you probably want to r/r and paint at the same time.
