#41
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 11-26-2013 at 09:04 PM. |
#42
My wife thought for sure I was going to put the top down.
#43
My engine is a full size Pontiac motor, not the original born with engine. It had a two barrel Rochester carb on it when I bought it, of course I didn't pay the big money for it and I am not afraid to drive it like a few of my other cars. The first thing I did was change out the intake manifold to a 66 4bbl one and bought a Carter carb. I hear that I need to find a 66 GTO engine as a replacement, and that is the plan. I thought that the full size block and the GTO block are somewhat the same, and that in 66 there is not a partial vin under the code. I know that they are coded differently, why is that? Different cam? I know the intake and carb swap didn't really change the performance on my car much, although I haven't tuned it since the swap. The engine has 091 heads and I believe the GTO motor had 093 heads. I have been advised that changing heads would not show much of an improvement in performance not sure why.
To get to my question: if I buy a 66 GTO engine instead of putting more money (acquiring heads, cam, distributor etc...) into my 66 full size 389, is all that it buys me, the correct code on the block? Hope this is not taken as high jacking your thread. I'm just trying to gain information on the advantages of putting a NOM car back to as close to factory, when the original motor is long gone ![]() Thanks for any advise.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
#45
Except for the codes, the blocks are the same. Although I got lucky and my cars are matching numbers, I don't think that its worth spending the money to change out the motor. I'll probably make members mad, but in my opinion, as long as the engine looks original,and performs well, I'm good with it. Now, if you want to go fast, then its a different ball game.
#46
Charles, I agree with Andre. Make the best of what you have. Unless you are after a trophy at a Pontiac event, the numbers won't matter to anyone looking at it. Besides, if you go after a 66 GTO engine you also have to worry about date codes, matching carb, etc..
#47
Paul,
Looks like you have a bit of other things to work on long before dealing with rims & tires. IMO and as stated those R1 rims look great and would/could look better with the goo wiped off the rubber and the drums detailed as factory, it will make the Rims POP. Add to that a Red upper body stripe and it would all pull together. Best of luck and do what YOU wish and enjoy the hell out of her!
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
| The Following 4 Users Say Thank You to Jeff Hamlin For This Useful Post: | ||
#48
I believe it was '66 only. My new '67 with Rally I's didn't have them.
Bill Nawrot (Wino Bill) 1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019 Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/ YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU 1967 GTO Conv |
#50
Someday Id like to see the other GTO's you have Bil. I'm a stacked headlight guy through and through.
#51
Looks like a nice ride Paul.
Have you put a wrench on that water pump bolt to check for tightness? I might loosen it off and rub a little sealer behind it and retighten it, just for laughs. Can you get CCass to change your name to old brown 66. I'm struggling with the picture/name mismatch.......
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
#52
Old Gold has a nice ring to it actually....
Greg Reid Palmetto, Georgia |
#54
Pul, no offense meant. I couldn't tell if the carb was a 2 or 4 in your first photos.... looked like a 2bbl to me.
![]() In my mind you have a exceptional 66 GTO even with the few little problems it has. But I know you'll put it right... they way you want. It's your so fix it up and drive it the way you want. Enjoy it to the fullest.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#55
Yes, there are certain people on these forums that you know will raise their cars to the next level or even beyond.
| The Following User Says Thank You to arbys For This Useful Post: | ||
#56
Gobble Gobble (Thats turkey for Happy Thanksgiving!)
#57
And a very Happy Thanksgiving you and yours Paul.... Also to everyone else here at PY and your families too.
Remember... "Plop plop fizz fizz, oh what a relief it is.
#58
Purchased in 1979, started frame off April 1,1983 still not done (30 years must be a record) this is how it looked a couple months back. ![]() I bought this one as a basket case in 1982. Patti and I restored it (with help on the paint) in the Summer of 1985.
#59
Naw.... that wouldn't happen. LOL
#60
![]() Did your car have a black top on it Gary? I sent for the PHS. Im sure there wont be any surprises. But Im curious to see if the car came originally with the Rallye I's. If the motor was swapped out, who knows, maybe it could have been an air conditioned car with a tri-power originally. |
