Old 12-07-2013, 01:29 PM
transam1972 transam1972 is offline
Default bracket
I am confused..did 80 amp get a rear holding bracket or not...sorry about this
Old 12-07-2013, 02:44 PM
njsteve's Avatar
njsteve njsteve is offline
The 80 Amp alternator, which is the one that is mounted in a non-adjustable position (the idler pulley sets the adjustment) has a large bracket in the rear with a spacer. If you ordered A/C and the rear defogger - the glass with the electric grid, you got the 80 Amp alternator. Here is a shot of the bracket and spacer and bolt from my 73 SD. Both of my 72's had the same set up as well.
BTW, the bracket is actually grey phosphate and not painted.
ID:	345790   Click image for larger version
The Following 3 Users Say Thank You to njsteve For This Useful Post:
Old 12-07-2013, 11:38 PM
Formulabruce's Avatar
From what I have seen in Parts cars..., a Combo of AC and Power windows could get this 80 amp set up as well. Just an observation, not saying its Gold...
" Long may we DRIVE !"
Old 12-08-2013, 09:14 AM
Bentwheelbob's Avatar
Default Paid my dues
Well, I am set for another year of fun with the cars in the Hot Rod Garage. The family and I are in NYC for our annual December pilgimage. We've been coming here at Christmas time since at least 2006 and it's become a great tradition. Yesterday we did some serious shopping and my wife got a small tokeen of my love and affection for her. This should see me through a repaint on the Black Car and maybe a new addition to the fleet. I'm thinking maybe a lucy blue Trans Am.... Thank goodness there does not have to be a 1 to 1 relationship.
BTW - I have two NOS thermac sensors at home waiting for me to return and test. Has anyone else broken out the vacuum pump and heat gun???
Old 12-07-2013, 03:18 PM
unruhjonny's Avatar
80 & 55 amp both had them, they were just slightly different.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 12-07-2013, 03:35 PM
Default bracket
I have a/c and edf...80 amp. setup but now realize I am missing the rear bracket...most everything seems to be complete and correct except that...I will have to find those parts.. at 58k it was missing some stupid stuff...like the clip for the purge hose..the passenger side heat stove and now this...thankyou for your help everyone
Old 12-30-2013, 09:58 AM
70RAlll 70RAlll is offline
Sorry..not Rustoleum, Krylon Semi Flat Black. Here is an Amazon link. $7.74 can with Amazon's free shipping. They show cheaper at $5.99 but you pay shipping..
http://www.amazon.com/Krylon-RTA9203...emi+flat+black
The Following User Says Thank You to 70RAlll For This Useful Post:
Old 12-30-2013, 02:08 PM
looks like a very good choice
Old 01-02-2014, 03:23 PM
Bob.. Chuck just called me unrelated to your parts. I mentioned your post here and he is interested. He is a great guy, known by many in the Pontiac world. Gave him this link and he will be contacting you. Great resource for NOS parts you may need.He currently has 2 crates full of 68-76 Firebird parts that they are just now getting sorted out to sell. I am sure there are parts you will end up needing that he will have, I smell possible trades before he list the parts?? I know he will pay cash as well, so my comment about trading was just a thought.... Good luck..
Old 01-19-2014, 10:49 PM
Default Don't Let This Happen To You - Really
OK, time to come clean. Sort of like confession. I bought myself a second four post lift for Christmas. Kind of a Merry Christmas to me offset to the blue Tiffany box. I got it put together the Saturday before Christmas and after getting it adjusted and in position I couldn't wait to get a car on it and up in the air. At about the 10:30 that night the Red Car was loaded up and raised. I took it up, brought it down. Took it up again and brought it down again. Everything looked good, so I started taking it up to full elevation and that's when all h_ll broke loose.
The seal in the hydraulic cylinder failed and the whole car started coming down. The lift has safety guards for such a situation, and it sort of worked. The problem is that the drivers side rear was just high enough to catch to upper safety lock. The passenger side rear was enough lower that it came to rest 5" lower. The driver's front also settled on the lock 5" lower. By this time the whole lift was twisting and had become unstable. I was holding onto the front driver's side leg trying to keep a total collapse from occurring. Ultimately the passenger front locked in about 1.5' lower than the driver's rear. It was ugly. There was hydraulic fluid everywhere, I was holding onto the lift, my neighbor Ken was in shock, and the Red Car was about to go through the garage wall.
When all was said and done the whole mess stabilized, but barely. Each post was leaning about 20 degrees off of plumb and resting on only one corner of the base plate. I could have pushed it over with about 10lbs of force. Talk about a mess....I called My Pal Dave and MPD, my neighbor Ken and I quickly went to work. We secured the top of the posts using binder straps hooked to the ceiling bar joists. We also anchored a chain to the wall with Hilti anchors and secured straps between it and the bottom of the posts to keep them from kicking out. About 2:30am that morning I went to bed hoping that when I woke up the car would not be sticking through the garage wall.
Well I got up about 7:00am and the car was still standing. I called two fantastic neighbors over and we devised a plan of action. One of them had a good friend that runs the local All Crane branch. All Crane dispatched two of their best guys on a Sunday and they showed up with a 9000lb Fork Lift, a cube of crib timbers, chain hoists and a bunch of steel to bridge the bar joists. The other neighbor dispatched his best guy from the manufacturing facility he owns with more steel, chain falls and a service truck. Ultimately we secured the whole structure with chain falls, cribbed the rear of the lift solid, and used the fork lift to elevate and level the front of the car and lift. Once this was accomplished, we started lowering the whole thing 6" at a time. By 5:30 the car was on the ground and the only things damaged were my pride and pocket book.
The lift manufacturer stood tall and agreed to replace the lift. I spent the next weekend tearing down the old lift, and last weekend installing the replacement lift. All is now well. Here are some pictures of the mess.
Be careful and have great friends.
The Following 2 Users Say Thank You to Bentwheelbob For This Useful Post:
Old 01-19-2014, 11:18 PM
njsteve's Avatar
Holy crap! Glad it all got fixed and the car is on the ground now.
The Following User Says Thank You to njsteve For This Useful Post:
Old 01-26-2014, 10:40 PM
That scared the he]] out of me just reading about this fiasco.
DaaaammMMNNN what a muhfukcer that was !
Glad all is well Bob
Old 01-26-2014, 06:39 PM
Bill,
Thanks for the recommendation. I received the master cylinder back from White Post last week. They fixed the seal and sprayed some type of finish coat on it, but it wasn't much of a finish. The whole unit was covered with some type of oil and simply wiping it off also wiped off the finish. I media blasted the master cylinder and sprayed it with the recommended Krylon Semi Flat Black. We got it installed this weekend and it looks great.
Here's a couple of pictures.
Old 01-26-2014, 07:01 PM
njsteve's Avatar
Looks good! Glad they were able to re-fix it.
